What LED 194s for Cluster/Gauge replacement - Chevy Impala SS Forum
 2Likes
post #1 of 29 (permalink) Old 10-23-2018, 08:09 AM Thread Starter
juniorwatson's Avatar
Guys,
I'm looking into getting all of the bulbs replaced in my cluster, and would like to get the opinion of the folks here who have dones this or something similar with the LEDs now available @ SuperBright LED 194 Bulbs
1. How many are required for the cluster?
There's a wide variety for the 194s, and I'm not sure of the difference between them.
Then I'm not sure of:
2. The style; 1-bulb, 5-Bulb, 5-Bulb tower
3. The Brightness; Cool, Natural, Warm
I'd appreciate any input, suggestions, or first hand experience stories too.
Thanks!
1LED
5LED
5LED-TOWER
juniorwatson is offline
post #2 of 29 (permalink) Old 10-23-2018, 09:07 AM
gbhs72's Avatar
Junior, I would go with the first bulb. Look at the angle of light output. For a dash the light should more directly toward you. The last bulb (360*) would be good for a floor shifter where you need light to illuminate the entire area of the PN123O. I may be wrong but I would go with that line of thought if it were me.
Mark: Snowman-33
gbhs72 is offline
post #3 of 29 (permalink) Old 10-23-2018, 10:47 AM
Z09B4U's Avatar
If my memory is correct the 94-96 Caprice gauge lights are placed in side a clear plastic light directors. The four bulbs for the gauges are above or to the outside edge of the gauges. The "bulb" has to shine left and right (from driver's view) not forward (straight at driver). There is a thread where a forum member claims that a vendor has a very wide angle LED that works. Some will create dark spots or shadows when used with light directors. The "gear indicator" seems to shine forward.
Like light bulbs different LEDs will react differently to the dash dimmer. Most will be hard to reset to the level you like.
Most people would only need to replace the normal bulbs one or two times in the life of a car. They are cheap and known to work. The "right" LED replacement may be out there but the $$ and time to find a good one is huge.
The only way you could convince me to switch is if I could in person see a identical or similar construction dash lit with LEDs. Pictures are useless to compare with.
Z09B4U
Z09B4U is offline
post #4 of 29 (permalink) Old 10-23-2018, 10:53 AM
gbhs72's Avatar
Lightbulb
https://www.rockauto.com/en/catalog/...ght+bulb,11730
https://www.ebay.com/itm/10-PC74-Twi...frcectupt=true
More colors available on Ebay.
Mark: Snowman-33
gbhs72 is offline
post #5 of 29 (permalink) Old 10-23-2018, 04:19 PM Thread Starter
Thanks for input fellas. I haven't made a decision, it was just one of those thought of: 'While I'm at it, I might as well replace the bulbs...."
I don't know anything about directionality built into the cluster.
Thanks for the help.
post #6 of 29 (permalink) Old 10-23-2018, 06:00 PM
Junior
If doing LED I would go with the Phillips one from RA that was posted. Its diffused cap will mimic better the incandescent (stock) bulb in terms of beam spread and not be "spotty" like the single or multi LED chip ones
Not sure these are dimmable
The cool or warm refers to the color temperature the light puts out. 5700k is considered "daylight" which would appear more "white" to the eye (6000k+ even more) vs warm which is 3200k aka "incandescent". That would be a personal preference as how you want the gauge cluster illuminated. LED can be harsh so you would want dimmable. IDK if our B-body dimmer works with LED. Maybe someone who has put LED in can advise
BALLSS is online now
post #7 of 29 (permalink) Old 10-23-2018, 07:49 PM
Jimpala95's Avatar
Junior, I've had excellent results using these LED's in all the Z clusters I've prepped/installed.Accents the cluster very well,without being too bright and bleaching out the numbers. You'll need 7 of them for the cluster illumination.The stock bulbs in the Z cluster are all 161's,way to dim imho. For turn signals/high beam indicators I toss the 161's and use oem 194 bulbs.Brightens up and actually enhances the colors of them.LED's in these 3 positions bleaches out the color,imo.
Also,get the right bulb bases,you need the bases locking tabs when installed to be at 11a-5p position like the oem bulb bases/sockets.Most of these aftermarket bases/sockets lock in at 12p-6p position,which over shoots the solder contact pads on the board.
In the pics below I show the 7 illumination bulbs from backside of cluster.Then with the turns/high beam bulbs lit up.Also in the backside pic with the 10 blue 11a-5p sockets,the 3 with yellow crayon are turns/hi beam.The other 7 blue are panel illumination positions.
And yes,you'll have no issues with full dimmer adjustability with these led's.
Hope this helps, Jim
Links to the Led's and correct 11a-5p bulb basesI've had great results with.I like the canbus style,but either style bulb base will be fine.
https://www.superbrightleds.com/more...%20Remarketing
https://www.superbrightleds.com/more...rofit-car/206/
https://www.ebay.com/itm/GM-instrume...item56a0baa7fb
Jimpala95 is offline
post #8 of 29 (permalink) Old 10-23-2018, 09:21 PM
Consider using green leds for turn signal indicators,and blue for high-beam. Quite dramatic effect for those who like that sort of thing...
Jimpala95 likes this.
post #9 of 29 (permalink) Old 10-23-2018, 11:29 PM
4x4high's Avatar
Subscribed for future use in my Z-cluster install.
The link with the CAN bus LED's did you go with the warm 3100 LED's?
1996 DGGM Impala SS
4x4high is offline
post #10 of 29 (permalink) Old 10-24-2018, 11:44 AM Thread Starter
Jim,
Thanks for the help, the pictures look excellent! I appreciate the help, and will be moving in that direction.
gbhs72 likes this.
