Good interior plus parts if you are in Michigan - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 11-25-2018, 08:08 PM Thread Starter
I found a 1994 Impala at my local junkyard https://youtu.be/GffKA6FRHMI
LilJerry100 is offline
post #2 of 3 (permalink) Old 11-26-2018, 05:02 AM
juniorwatson's Avatar
Damn, I've NEVER seen an Impala, just donked out Caprice cars by the kids at Fort Hood. Take what you can, especially the LOWER dash and cluster trim if it's still there.
I picked up one a few weeks ago for just $16. It was the FIRST time I have ever seen a dash in tact. Everyone else rips the $hit out of stuff to get at whatever they need.
juniorwatson is offline
post #3 of 3 (permalink) Old 12-05-2018, 06:44 AM
GreenWitINv's Avatar
Is the car still there? I’m down by Kalamazoo
GreenWitINv is offline
