Vacuum line question - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 12-25-2018, 03:52 PM Thread Starter
ocala's Avatar
Another question...
Anyone know where this vacuum line goes? Iím putting the heater box back together. This flopped down, Iíve looked all over, pulled the ashtray etc.
Canít find where it goes...
Thanks all.
Sent from my iPhone using Tapatalk
ocala is offline
post #2 of 11 (permalink) Old 12-25-2018, 04:26 PM Thread Starter
ocala's Avatar
If this helps, it comes from a harness in the engine bay, itís hard black plastic. I think it might go up to the top of the engine.
Inside it goes to a connector, and then to amore flexible line with the end that you see.
Could this just be a vent?
Thanks again
ocala is offline
post #3 of 11 (permalink) Old 12-25-2018, 05:05 PM
Suspect it goes to the vacuum harness that goes to the HVAC selector part of the HVAC controls.
post #4 of 11 (permalink) Old 12-25-2018, 06:29 PM Thread Starter
ocala's Avatar
Thanks for the reply 1slow96. I figured it out. Itís the main vacuum line going into the vacuum tank. #66 in this diagram:
That connection got pulled out when I was wrangling the heater box bottom into place. That piece is so far up I could barely see it, much less reach it.
I used a inspection scope to see it. Then I used a screw grabber to position the fitting on the end of the orifice. Then I let it go and finally used a long screwdriver to push it into place. WOW!
I thought I was going to have to pull the dash. My heater controls now work, and they didnít before I put this back in.
I think itís time to put away my tools haha.
ocala is offline
post #5 of 11 (permalink) Old 12-25-2018, 07:00 PM
gbhs72's Avatar
Ocala Said "That connection got pulled out when I was wrangling the heater box bottom into place. That piece is so far up I could barely see it, much less reach it.
I could have sent my Urologist to reach it. Hit my gag reflex.
That book sure helps, glad you got it squared away.
Mark:Snowman-33
gbhs72 is offline
post #6 of 11 (permalink) Old 12-25-2018, 08:19 PM
Knowing when to quit,and declare victory is part of the B-Body game.
post #7 of 11 (permalink) Old 12-26-2018, 09:17 AM
Banned
over 10 yrs ago I did remove the dash top cover not a hard job.. reason I did it was , I had to dye the dash cover . was turning brownish .. used water based light gray UV resistant DYE..
I did check out the wiring and those vacuum lines when I removed the dash cover .. did cleaning and some wire/hose protections..
j cat is offline
post #8 of 11 (permalink) Old 12-26-2018, 03:23 PM Thread Starter
ocala's Avatar
Yeah I refer doing that with my Impala. I covered mine with vinyl though. It already had cracks in it, I could have filled and sanded it, but the vinyl looks pretty good.
That said, I wouldn't want to pull the dash just to replace that vacuum line. I lucked out on that one.
ocala is offline
post #9 of 11 (permalink) Old 12-28-2018, 03:38 PM
Banned
I lucked out no dash cracks .. I also have 84 camaro dash has no cracks .. have used the vinyl armor all protection ..
j cat is offline
post #10 of 11 (permalink) Old 01-01-2019, 06:58 PM Thread Starter
ocala's Avatar
I never used the armor all, but apparently it works really good for some people.
Having a garaged vehicle in a northern state probably doesnít hurt either haha.
ocala is offline
