Repairing Plastic Dash - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 02-04-2019, 02:39 PM Thread Starter
gbhs72's Avatar
I have done some research and can't seem to find what I'm looking for. I'm putting RM dash in my Caprice and I had routed out a section to put my Caprice badge in it. While I was doing that I removed a little too much and now have to fill it in some to make it look proper. Right now the only thing I can think of is to use some 2 part epoxy to fill it and then finish it to look right. Color is not an issue as I'm going to paint the dash bezel.
Thanks for all suggestions.
Mark: Snowman-33
gbhs72 is offline
post #2 of 5 (permalink) Old 02-04-2019, 05:50 PM
I use JB-Weld with,or without some type of reinforcing cloth for rigid plastic parts of lower dash,and door panels.
post #3 of 5 (permalink) Old 02-04-2019, 11:24 PM Thread Starter
gbhs72's Avatar
1slow, I appreciate your comment. I too thought of JB Weld. I just always thought of it for metal repairs. It would have to be sanded down to match the contour and of course primed before paining. Thanks a bunch. I'll give it a try on a broken unusable bezel I have.
Mark: Snowman-33
gbhs72 is offline
post #4 of 5 (permalink) Old 02-06-2019, 06:37 AM
TGO
I used this stuff to fix the body cladding on a Typhoon I had for a short while...
https://www.3m.com/3M/en_US/company-...3242001&rt=rud
Once it hardens you'll break the plastic before breaking the bond.
I intend to use some to fix the crack that's forming in my door panel. If nobody buys the car at least lol
2001 Corvette ZO6
1995 Impala SS - H/C/I - BBB
TGO is offline
post #5 of 5 (permalink) Old 02-12-2019, 12:40 PM
SoCalChlln's Avatar
I use a two part plastic epoxy just as you thought of. I apply it to the back of broken parts with a piece of tape on the front to keep the form and the repair smooth, then use SEM’s Filling primer to do any smoothing, sanding or shaping of the repair.
I think you already have this figured out but let me know if I can help any further with interior refinishing. I’ve done a bit to my Gray interior of my 96 SS...
K&N Gen II Cold Air Intake, HB Removed, Jet Airfoil, TB bypass, Stealth Brake Biasing, Cat Back Exhaust w/ side by side crossover.
SoCalChlln is offline
Similar Threads
Repairing a Sears Craftsman Hydraulic Floor Jack SAH62 Engine Problems/Maintenance 9 10-19-2012 09:56 AM
Repairing Racetronix Fuel Pump Harness Gene Engine Problems/Maintenance 1 03-24-2010 08:25 AM
Repairing hinge pin door help 92SS wagon Wagons 5 01-23-2010 01:40 PM
Repairing missing door clips BYB_CUZ Interior 4 06-14-2008 05:38 PM
Repairing Torn Tint Oldtimer Wagons 4 11-10-2007 08:51 AM
