Mileage indicator - Chevy Impala SS Forum
post #1 of 18 (permalink) Old 02-20-2019, 11:23 AM Thread Starter
Mileage indicator
96 impala my mileage is not showing everything else is working fine
biged0082 is offline
post #2 of 18 (permalink) Old 02-20-2019, 11:42 AM
KingsKrew's Avatar
Search→ Odometer
1996 Impala SS
1996 Caprice sold
KingsKrew is offline
post #3 of 18 (permalink) Old 02-20-2019, 11:42 AM
you likely have the classic cold solder joints on the resistors on the instrument cluster for mileage read out. Common on 96
Often just "re melting" the solder fixes the issue.
Removing the instrument cluster is not hard. Use a low watt soldering iron with small tip
There likely are several "how to" videos if you search
post #4 of 18 (permalink) Old 02-21-2019, 09:38 AM
$25.95 plus shipping
https://www.impalasuperstore.com/sup...cat=Electrical
Pull instrument cluster, replace burnt resistors, mount heat sink somewhere, put back together. Easiest job on the car.
Blakjack is offline
post #5 of 18 (permalink) Old 02-21-2019, 03:23 PM
Thanks there Blak- I had VERY infrequent odo fade on my SS some time back, but haven't noticed it for years since. It's been getting more noticeable now with this weather. I usually don't drive it in winters, so it may have been a freezing weather issue for quite some time. Anyway, will be ordering the kit thanks again. And din't realize NAISSO still out there. Now do they still have those 140mph window stickers hmmmm...
post #6 of 18 (permalink) Old 02-21-2019, 04:55 PM
IDK the Impala SuperStore was still in biz but that is where I got my odometer fix kit SEVERAL years ago. Easy install but you do need to have the right solder iron or you can really FU the circuit board.
post #7 of 18 (permalink) Old 02-21-2019, 06:20 PM
Banned
I did this when my 96 Imp was under warranty .. dealer said it will take one week and they were gonna put another odometer in .. I said not gonna happen .. so I got info from other owners with this and I got the shop manual .. took me 45 min to simply resolder those odometer resistor joints .. using a 35 watt soldering iron and a small amount of rosin flux lead solder . still working 21 yrs now .
GM trucks have had these dash soldering failures over many years many other dash issues on GM Mexico work ..
DO NOT CHANGE THOSE RESISTORS !!!!!!!!!!!!!!!!! SOME DID !
j cat is offline
post #8 of 18 (permalink) Old 02-21-2019, 06:33 PM
Z09B4U's Avatar
See post #23 he uses three 100 Ohm 2 Watt resistors. By using the resistor leads he bypasses the burnt circuit board.
https://www.impalassforum.com/vBullet...-w-pics-3.html
Z09B4U
Z09B4U is offline
post #9 of 18 (permalink) Old 02-22-2019, 01:04 PM
Banned
I have seen pictures of members showing the hack jobs done on the resistor changes .. the Idiots did that damage not to my liking.
j cat is offline
post #10 of 18 (permalink) Old 02-24-2019, 07:09 AM
Just got my odometer kit in the mail this week. He is an online-only order business these days, but he still has some of the goodies. We used to stop at his store on the way down to Daytona and I always brought home something that I had no intention of buying. Once it was the Stillen front bumper cover. Now that was fun to tote back home.
nickss96 is offline
Similar Threads
1996 impala cluster (Mileage Indicator) 9c1CincyChevyMan Electrical 8 11-10-2009 01:18 AM
Dakota Ditgital Gear Shift Indicator Mark Ross Parts for sale/wanted 10 08-31-2008 07:28 PM
Poor man's....or innovative man's gear indicator for z28 cluster blackkodiak18 Interior 12 08-19-2008 02:56 AM
Qwk ? on dash indicator lights. jpalmer Interior 2 01-16-2008 04:49 PM
gear indicator cable Formula14 Interior 6 10-15-2007 08:52 PM
