New LED bulbs - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 04-17-2019, 12:09 PM Thread Starter
cadejohnson58's Avatar
New LED bulbs
Hello guys can you guys please tell me which bulb goes where, i bought these and they fit my car but they did not come with a description to where to put them. Thank you.
cadejohnson58 is offline
post #2 of 6 (permalink) Old 04-17-2019, 12:14 PM
Did you already ask where you bought them and they won't tell?
You might start your search using links from this and go from there:
https://www.impalassforum.com/vBulle...-led-kits.html
post #3 of 6 (permalink) Old 04-17-2019, 02:13 PM Thread Starter
I asked and got this
"I have checked for you
t10 type can fit
Ash Tray Light Bulb
Courtesy Light Bulb
Glove Box Light Bulb
Instrument Panel Light Bulb
Map Light Bulb
1157 can fit
Back Up Light Bulb
Brake Light Bulb
Rear Turn Signal Light Bulb" i wanted a description at least telling me in their picture from left to right where they go. It said it fit my car and they turn on but i like to make sure i have everything. And my map lights are tiny compared to these LED's dont know how thats gonna work. I also had to use a ziptie to keep my passenger flood/courtesy light from falling out but it does work and is bright.
post #4 of 6 (permalink) Old 04-17-2019, 03:39 PM
Ok, if you got "exactly" what's shown in the pic then there's one set of 1157 and they go to the taillight. You got 3 sets of one style plug and 3 of another. I'm guessing each one's different count of little squares is for increasing lumens, so pick for comparative desired illumination between the 3 for each type's corresponding locations.
post #5 of 6 (permalink) Old 04-18-2019, 12:12 AM Thread Starter
Thank you ill be looking for more 1157's then to do the whole rear lights. The small LEDs fit except for map lights maybe that takes some extra time to figure out if i really wanted them.
post #6 of 6 (permalink) Old 04-24-2019, 01:20 PM
I ordered that same set on eBay. The bulbs are a good value but that "kit" is not really for our cars. All of those at the top will fit the license plate light, under the dash/above the feet of each front passenger, and ash tray. Any of the bulbs will fit in any of these locations- your choice.
Bottom row of the pic: none of the first three types of bulbs fit anywhere on our cars. I was able to find a use for them in another vehicle. The last bulb is an 1157 style but it will not fit our tail light housing. While the base is an 1157 style, the area where the LED's mount to the bulb frame is wider than the 1157 base. On my car, this prevents the bulb from going in far enough to connect. If you are looking for the door panel courtesy lights and dome light, they each use a 44mm festoon LED.
94 Impala SS- 388 LTx, AFR 210cc heads, Lloyd Elliot cam, 11.67:1 compression, Nitrous Outlet 200 shot
old setup: Procharger, etc...520 RWHP
70 El Camino SS 396
72 Chevelle
70 Chevelle convertible
70 Chevelle hardtop
94SSman is offline
Similar Threads
FS: Amber 57 LED 2057 bulbs, pair 350 Parts for sale/wanted 17 06-25-2008 08:48 PM
Sequentials and LED bulbs..need assistance BigMan95Impala Electrical 7 12-11-2007 02:40 PM
Clear Corner and Headlight bulbs/LED Switch 95darkcherrieSS Exterior 3 12-03-2007 11:11 AM
New LED Bulbs AutocroSSer Exterior 7 04-10-2002 09:16 AM
