Dtc b1062 - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 04-28-2019, 08:26 PM Thread Starter
4x4high's Avatar
Dtc b1062
Figured this was probably the most appropriate section for my question. My SIR light came on so I hooked up my scanner and have a B1062 code but there is nothing in the DTC library to suggest what to look for, it just says it's a manufacturer specific code. I tried a Google search with not much luck. Anyone have any ideas? I tried to clear the code and it wont clear.
Found the required diagnostic procedure in my FSM.
1996 DGGM Impala SS
4x4high is offline
post #2 of 3 (permalink) Old 04-29-2019, 01:04 AM
What scanner? May need a newer or more high tech version for SIR.
grandpas wagon
grandpas wagon is offline
post #3 of 3 (permalink) Old 04-29-2019, 08:14 AM Thread Starter
4x4high's Avatar
I have a Launch Millennium 90 Pro.
1996 DGGM Impala SS
4x4high is offline
Similar Threads
DTC 84 then DTC 83... cadillac531 Fleetwood 2 03-26-2012 10:49 PM
DTC 84 then DTC 83... cadillac531 PCM Programming/Engine Management 0 03-25-2012 07:24 PM
DTC 84 then DTC 83 cadillac531 Engine Problems/Maintenance 0 03-25-2012 05:54 PM
Need Help: Getting DTC's 32, 44, 45 - 91 l05 9c1 Thelyricist720 Engine Problems/Maintenance 4 09-08-2007 04:26 AM
DTC 52, DTC 42 artgski Caprice 0 10-07-2002 04:22 PM
