What is this part ? - Chevy Impala SS Forum
 1Likes
  • 1 Post By MWP
post #1 of 3 (permalink) Old 07-23-2019, 07:55 PM Thread Starter
SoCalChlln's Avatar
I found this rubber part inside my drivers door while replacing the regulator.
Does anyone recognize the part and can you tell me where it is supposed to go.
I’m refinishing my complete door internals and don’t want to miss anything before I button it back up.
Any and all information is very appreciated...
Thank you...
K&N Gen II Cold Air Intake, HB Removed, Jet Airfoil, TB bypass, Stealth Brake Biasing, Cat Back Exhaust w/ side by side crossover.
SoCalChlln is offline
post #2 of 3 (permalink) Old 07-27-2019, 09:25 PM
MWP
Offhand, it looks like a broken window lower stop--item 62 on the diagram here:
https://www.wholesalegmpartsonline.c...roduct=2559371
pimpallya59 likes this.
MWP is offline
post #3 of 3 (permalink) Old 07-27-2019, 11:35 PM Thread Starter
SoCalChlln's Avatar
Yep... I do believe you are correct.
I stuck my head in the access hole and could see where it mounted ether bottom of the door, the bolt holding it in place had fallen out, so, a nyloc nut and new round head bolt and it’s back home where it belongs. It does appear to be a window stop for the bottom of the window should something with the regulator let go.
Thank you for the great diagram, it also helps me with restoring the door...
