A Pillar metal clip - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 08-14-2019, 08:10 PM Thread Starter
boofers's Avatar
A Pillar metal clip
Anybody know of a source to get these clips? one of mine broke off the pillar and would like to replace
1996 BBB, 396ci Golen LT4, Yank 3600, TransGo shift kit, 3.73s, P71 MMC driveshaft, CIA Tri-Y Gen II, X-Pipe, Dynomax UltraFlo exhaust, Hotchkis Sway bars & Springs, Bilstein Shocks, UMI extended control arms, ODBI conversion, all installed and tuned by Mike Harris
boofers is offline
post #2 of 7 (permalink) Old 08-14-2019, 09:46 PM
Contact Fred Kiehl. I got a A pillar molding from him
BALLSS is online now
post #3 of 7 (permalink) Old 08-14-2019, 10:29 PM Thread Starter
boofers's Avatar
Already contacted him, didn't have one readily available but because of the odd shape, shipping might be pricey.
boofers is offline
post #4 of 7 (permalink) Old 08-15-2019, 06:07 PM Thread Starter
boofers's Avatar
I might go this route
NEW 94-96 IMPALA SS CAPRICE TRIPLE A PILLER GAUGE POD - Turbo 6 Performance
looks like it is the whole pillar and not just an overlay. I have gauges I want to mount and with a broken tab I don't want to put any stress on the remaining one with the extra weight (plus it sags)
boofers is offline
post #5 of 7 (permalink) Old 08-15-2019, 08:42 PM
If it popped off in the pillar, you can reweld it to the trim piece with a soldering iron. You may have to add some material, or at least reshape the material that is there. You asked me for a gray pillar. I said that I only had other colors. The gray ones are hard to find.
post #6 of 7 (permalink) Old 08-16-2019, 06:36 AM
juniorwatson's Avatar
I may have a broken pillar in my storage.
LMK if you're still needing this clip and I can look into it tonight when I get home.
juniorwatson is offline
post #7 of 7 (permalink) Old 08-16-2019, 09:39 AM
OP if you can't repair yours as Fred notes (JB Weld is also a way to secure the clip) you can use any color A pillar trim and paint it with SEM. I used their primer then the grey spray paint
That is what I did when I got a A pillar from Fred when I added a pillar gauge as I did not want to drill my stock Grey one incase I ever wanted to delete the oil pressure gauge I installed
Name:	Gauge-A Pillar paint.jpg
Name:	Gauge-A Pillar2.jpg
Name:	Gauge-A Pillar.jpg
