Removing Instrument Panel Trim - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 09-04-2019, 10:26 AM Thread Starter
Hi,
I installed a Z-28 cluster a long time ago, and it took me a while to find out about the resistor removal to get the oil pressure gage to work. I know it's behind the glove box door, but it appears I also have to remove a panel that's behind the door. I believe it's only held in place with clips, but I don't want to break anything. Anyone have a tip for removing this?
jiml is offline
post #2 of 4 (permalink) Old 09-04-2019, 11:31 AM
juniorwatson's Avatar
Originally Posted by jiml View Post
Hi,
I did this about 10 years ago on a write-up that HuSSker did, and it's a resistor wrapped in black electrical tape that is in the area behind the glove box. There's n other panel that I recall in that area. Once you remove the box, you should see a conductor that's got black electrical tape around it, and typical resistor is soldered in series.
That's all, just remove the box, and look at the wiring in the area.
juniorwatson is offline
post #3 of 4 (permalink) Old 09-04-2019, 01:20 PM Thread Starter
I removed the box, and the trim panel I was talking about. I don't see a harness. There is a harness in there but there's no access to it without taking most of the dash apart. Unless I'm doing something wrong, which has been known to happen
jiml is offline
post #4 of 4 (permalink) Old 09-04-2019, 04:10 PM Thread Starter
Okay I figured it out.
The harness is in between a dashboard bar and the dash itself. The photos I found (thank you) show that harness pulled down to get access to it. I did have to remove the trim panel. There are 2 clips holding the harness in place, and they're behind the panel. A little squeeze and they pushed through. Then I was able to pull down the harness. Removed the electrical tape and found 2 wires wrapped separately. Who invented this stuff? ugh!
There's a tan wire in the harness. One end of the 68 ohm resistor is tapped into this wire. The other end is connected to a black/white stripe wire (ground, according to my manual). I cut the resistor off the black wire and viola, I have a real oil pressure gauge! I cut the resistor completely out, and taped over the bare part of the tan wire. I then taped the entire harness replacing what I had cut off. I used blue electrical tape. Why blue? First, because I can. And second, 25 years from now someone is going to be restoring this car, pull out that harness, look at the blue tape and say who the f* would do this? Somewhere I will be giggling.
Once again the forum teaches me something. Thank you!
jiml is offline
