Removing Power Mirror Switch - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 09-29-2019, 08:55 AM Thread Starter
rbh
Having trouble removing power mirror switch, looks like a pin hollds it in. The pin is not interested in coming out. Anybody have any suggestions?
Randy
rbh is offline
post #2 of 4 (permalink) Old 09-29-2019, 12:32 PM
jayoldschool's Avatar
Not a pin, it's a small allen head set screw.
jayoldschool is offline
post #3 of 4 (permalink) Old 09-30-2019, 04:39 PM Thread Starter
rbh
Thanks, apparently after 2 years the set screw is bonded to the brass insert. Going to have to drill it.
Randy
rbh is offline
post #4 of 4 (permalink) Old 09-30-2019, 05:44 PM
This is a large difference in scale, but:
LAst month I had to get the shaft pulley off my table saw, but the set screw was seized on the woodruf key to the point I would either break the allen wrench in the head - or round off the hex. No access for a mapp torch. I didn't want to diassemble the whole dam saw so on a lark I got a rotohammer set to 'chisel' and just let the bit rest on the shaft. 15 minutes of steady torque plus PBBlaster shook it loose.
Don't know the accessibility but maybe some dissolver and oscillating dremel vibrating everything?
