Transmission Cooler Lines - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 03-25-2019, 10:01 AM Thread Starter
Has anyone replaced the transmission cooler lines from transmission to front of car. When I removed mine they were twisted up pretty bad at transmission.
dans95 is offline
post #2 of 9 (permalink) Old 03-25-2019, 12:19 PM
Send a message via AIM to FaSSt9602
You can use AN fittings and hose to replace. I'll have to dig around for the links here on the forum. Most keep the hard line sections near the radiator and just use tube to AN adapters.
1996 DGGM Impala SS
Project Resurrection 396 in the works!
FaSSt9602 is offline
post #3 of 9 (permalink) Old 03-25-2019, 12:30 PM Thread Starter
ok thanks do I need to flare the steel lines for the an tube nuts
dans95 is offline
post #4 of 9 (permalink) Old 03-25-2019, 02:13 PM
Blue Wail's Avatar
Make your own new ones with steel 3/8" brake line from Napa.
Bolt trans to engine before you drop it into the car to get the bends right.
Nab
Blue Wail is offline
post #5 of 9 (permalink) Old 03-25-2019, 03:44 PM
Not if you are going the AN route. The adapter fittings use a brass ferrule to seal to the existing hard lines.
https://www.summitracing.com/parts/e...6erl/overview/
1996 DGGM Impala SS
post #6 of 9 (permalink) Old 03-25-2019, 04:51 PM Thread Starter
Can i run the an in stock locations
dans95 is offline
post #7 of 9 (permalink) Old 03-25-2019, 04:56 PM
Like Nab mentioned, you could just fab up your own metal lines and do it cheaper too. I have seen the stock metal lines for sale up on eBay from time to time.
The rubber portions of these and the oil cooler lines typically will leak/seep fluid after a short while. A lot of members have switched to an ALL AN option from Trans to cooler(s) or some have just replaced the rubber portion in a variety of ways.
The last time I did this I put this thread together and should walk you thru the process or at least give you some ideas. I believe I also linked Bustabill's all AN thread as well.
https://www.impalassforum.com/vBulle...onversion.html
Edit - HAMILTON-Chevy has both lines (GM) for sale up on eBay right now. Here is 1 of them....
https://www.ebay.com/itm/Caprice-Tra...wAAOSwrY9a~cP2
As for actual replacement...it's pretty straightforward to do with the difficult part getting to the fittings on the Trans case. Removing the crossmember and "carefully" lowering the Trans (keep eye on firewall wires/hoses and don't pinch/crush them) should give you a little more access to the fittings.
post #8 of 9 (permalink) Old 03-27-2019, 08:19 AM Thread Starter
thanks for all your help guys, went with Hamilton cheyv for the oem lines just have to remove the temp sensor
dans95 is offline
post #9 of 9 (permalink) Old 03-27-2019, 04:56 PM
tayto is offline
Similar Threads
Brake lines - hard lines not flex lines Clear Image Auto (Dan) Vendor Area 28 06-09-2015 05:11 PM
Good Trans cooler for 2800 stall and stock cooler lines 95BLKSS Drivetrain 0 01-10-2014 09:16 AM
Oil cooler lines/Traney cooler lines Cliff H Engine Problems/Maintenance 21 01-16-2006 08:45 PM
Trans cooler, cooler lines and tc block delta8812 Drivetrain 1 09-12-2005 11:57 PM
Braided lines for Oil/tranny cooler lines. vandal835 Engine Problems/Maintenance 12 11-01-2004 05:24 PM
