Rear axle ABS delete plug/plate - Chevy Impala SS Forum
 3Likes
post #1 of 30 (permalink) Old 04-05-2019, 05:49 PM Thread Starter
babywag's Avatar
I searched but everything I found isn't for a GM 8.5 10 bolt?
Does anybody know of one?
Want something a little cleaner than a sensor with the wires cutoff.
babywag is online now
post #2 of 30 (permalink) Old 04-05-2019, 06:41 PM
gbhs72's Avatar
Hey babe, talk about timely. I'm interested in this too. The thought of that sensor with wire remnants just makes me cringe. I think I saw in my searching that it can be threaded and a plug put in. I'm not positive on this though. I will try to find out more info and let you know. BTW router extenders are great. I'm able to stay current now. The laptop is ok but a bit cumbersome in searching. I be back
Mark: Snowman-33
gbhs72 is offline
post #3 of 30 (permalink) Old 04-05-2019, 06:50 PM Thread Starter
babywag's Avatar
Yes, really wish would have run a ntp pipe thread tap in housing when it was apart!
Didn't occur to me...duh
Not sure I like that idea now with it installed in car...
post #4 of 30 (permalink) Old 04-05-2019, 07:09 PM
Sinister's Avatar
I just left the sensor in mine since it is under the car and I will never see it.
Tapping and plugging would be the cleanest approach though.
1slow96 likes this.
1995 Caprice Wagon
Sinister is offline
post #5 of 30 (permalink) Old 04-05-2019, 07:16 PM
gbhs72's Avatar
This is all I could find so far. Got any friends with a Tundra or Tacoma to compare? Might be able to modify a little to get it to work. https://www.summitracing.com/parts/t...0-13/overview/ I just got some more on this. It's most likely not the right size but measuring should get us there. I'm sure you'll get the idea.https://eastcoastgearsupply.com/i-49...eeze-plug.html
Mark: Snowman-33
gbhs72 is offline
post #6 of 30 (permalink) Old 04-05-2019, 08:20 PM Thread Starter
babywag's Avatar
Yeah I found many, just nuthin for 10 bolt which is weird?
I'll measure the hole in the axle I removed, maybe I can find a steel plug that'll fit?
post #7 of 30 (permalink) Old 04-05-2019, 09:27 PM
gbhs72's Avatar
I was looking up parts for my diff when I read your question. The rear is the only thing left on my frame right now. I'll be able to just tap mine. If I was in your situation with a recent rebuild I think I would lean toward a small brass expansion plug. My thinking is that water will remain in the cup and rust a steel one. Less trouble with the brass. JMHO Best O luck babe.
Mark: Snowman-33
gbhs72 is offline
post #8 of 30 (permalink) Old 04-05-2019, 10:32 PM
95wagon's Avatar
I would just make an o ringed aluminum plug
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #9 of 30 (permalink) Old 04-05-2019, 11:03 PM
MWP
A plug is okay but it doesn't take advantage of the two BIGGEST benefits of ABS delete--LEDs for speed, and the tachometer mod.
De-ABSing the car offers two options, especially with the B-body single channel rear ABS. (obviously different for Fleetwood 4-channel)
First, if you replace all the ABS sensors with LED lights your car will go faster. Some people like the blue ones but my friends used to tell me the reds were better. If you do just the front ones then most people will think you have front-wheel drive. If you go the extra step with the rear LED and get a clear differential cover [yes, those REALLY do exist] it will light up the gears at night so people know you have all wheel drive when you pass them. I added extra ground straps for the rear axle and it made a real difference.
The other option is to retain the reluctors and sensors, and use them to trigger something. Since they will be happening too fast to perceive, you either have to remove some of the reluctor teeth or install a circuit to trigger on every other tooth, or once a revolution, or somewhere in between. The B-body rear reluctor is spinning at a different rate than the front wheel ones, so you have count the teeth and do the math to adjust, or use it for another circuit. Possibilities--a drive-shaft triggered strobe light for backseat passengers to cause seizures when you do burn-outs.
OR, go all-in and do the tachometer net RPM mod. Not many people know about this one, so your car will be a real sleeper. In the old days cars were rated by gross horsepower, but we shifted to net (at-the-wheel) HP. BUT YOUR TACHOMETER IS STILL GROSS ENGINE RPM because it is cheaper for car makers to run a wire to the engine than all the way to the back, especially in a long car like a B/D body. So, if you use the rear ABS sensor as the tach input, you will get NET DRIVESHAFT RPM. The oil companies don't want you to know this because it is one of the easiest ways to reduce fuel consumption. It also is a better way to determine optimum shift points because believe it or not the transmission gear ratios actually CHANGE from 1st to 2nd to 3rd and so on. That's right--so it is hard to keep things "in the zone". The problem is that your tachometer is still measuring gross engine rpm, so you are only guessing at the net rpm.
Just ask this scientician:
gbhs72 likes this.
MWP is offline
post #10 of 30 (permalink) Old 04-06-2019, 12:05 AM
gbhs72's Avatar
DOH!!!!!!!!!!
[/COLOR]
Ahh today is the 6th of April not the first. BTW, Do you sell ice cream. Such Good Humor
Mark: Snowman-33
gbhs72 is offline
Similar Threads
WTB Rear Axle End Plate Todd TCE Parts for sale/wanted 10 03-06-2014 08:30 AM
Delete-delete-delete Needles.Kain Misc. 1 08-06-2010 08:45 AM
New home plate delete plug "cover"!!!!!!! rwjjr Engine Performance 18 03-20-2007 05:30 AM
I need line from ABS to rear axle. Were and how? 96greengrey Brakes 5 06-02-2005 10:34 AM
Home Plate Delete - Unusual Plug Captain Crankshaft Engine Performance 23 06-21-2002 03:06 PM
