Need someoneís advice - Chevy Impala SS Forum
 1Likes
  • 1 Post By 1slow96
post #1 of 6 (permalink) Old 05-12-2019, 12:46 PM Thread Starter
claycoboi's Avatar
I have an all original 1994 impala. Transmission went out on me. What other transmission can I swap in? Reason Iím asking is cause I have two good ones in the garage. One from a 88 Chevy 1500 van and another from a 2000 Tahoe two wheel drive. Any input is appreciated. Thanks
Sent from my iPhone using Tapatalk
claycoboi is offline
post #2 of 6 (permalink) Old 05-12-2019, 02:29 PM
babywag's Avatar
Neither is a good choice IMHO.
The 88 is probably actually a 700r4, and the 00 is probably the removable bellhousing version.
The 88 would need a cable setup, and the 00 would need to be properly spaced to TC, wiring and pcm changes.
https://www.impalassforum.com/vBulle...ies-links.html
babywag is offline
post #3 of 6 (permalink) Old 05-12-2019, 02:30 PM Thread Starter
claycoboi's Avatar
I thought so. Thanks for the advice. Rebuild on the way I guess
post #4 of 6 (permalink) Old 05-12-2019, 07:48 PM
Original case/wiring is by far the most foolproof. There are many variants of the 4L60-E. Some are compatible,most are not. Rebuild by a specialist with some upgraded internals is the smart play. Consider a quality 9.5" converter,the install is basically free.
sherlock9c1 likes this.
post #5 of 6 (permalink) Old 05-12-2019, 07:49 PM Thread Starter
claycoboi's Avatar
post #6 of 6 (permalink) Old 05-13-2019, 08:26 PM Thread Starter
claycoboi's Avatar
Just curious if anyone has ever run into this. Was driving my car the other day and came to a stop in traffic. Once light turned I hit the gas and car just revved up. Wouldnít not go in any gear or reverse. After I got to the side of the road and set for a while it crunk up and drove fine. It like when the transmission gets hit it quits. Let it cool down and it drives fine till itís hot again. Anyone ever have this happen?
Similar Threads
Need Advice and need it quickly! log1k Exhaust 4 06-13-2014 04:31 PM
advice for a locked motor?and advice IDing it 94roadiewagon Engine Problems/Maintenance 15 04-29-2009 07:08 PM
need advice on wheel and tire set up need adice need pics socal ss Wheels & Tires 3 02-03-2009 02:04 PM
Need new radiator... need advice SHYHEIM919c1 Engine Problems/Maintenance 2 06-12-2006 10:59 PM
need 315's need advice prossound Wheels & Tires 15 12-17-2000 08:29 PM
