Car at Shop for Almost 2 Weeks - Advice? - Page 2 - Chevy Impala SS Forum
 1Likes
post #11 of 13 (permalink) Old 06-12-2019, 11:33 AM
Sophomore Member
Good trans builders are always willing to fix their stuff (not necessarily at their cost), it helps them learn and improve, and for the customer it keeps "only one chef in the kitchen" so there's no fingerpointing. I'd also invest in a line pressure gauge - honestly this will tell you of problems far sooner than a temperature gauge. Get a 0-300psi one off of Ebay.
sherlock9c1 is offline
post #12 of 13 (permalink) Old 06-12-2019, 04:06 PM Thread Starter
ATX_Impala's Avatar
So the tranny has to be taken apart and it's most likely the pump or valves, possibly both. I must have misunderstood on an "additive" but believe he was referring about something in regards to pressure testing. Hoping my torque converter isn't fried too! Anyhow progress on this whole thing has been made and I feel better at least knowing something is being done.
4x4high likes this.
Taking it one day at a time...
ATX_Impala is offline
post #13 of 13 (permalink) Old 06-18-2019, 10:14 AM
Blue Wail's Avatar
I'd make sure the tranny cooler lines are bypassing the radiator and going straight to the external cooler.
If the tranny lines are going into the radiator, the radiator could be leaking antifreeze into your transmission
causing the problem.
I'd also install a 2nd plate style external trans cooler.
Also check that the converter is locking up in OD- if not it'll burn up quick!
If you need a new trans I'd also 2nd a Performabuilt trans rather than a stock rebuild.
Even their stage 1 is stronger than most shops stage3.
Nab
April's Sparkle Cat
383 LT1 12:1 flat top + 75 shot
11.66 @ 117 at SSHS17 Nov 11, 2017
2017 12.0 Index Champion
4140 lbs. w/ driver. front sway bar ON
Powered by 4L80E! (controlled by LT1 pcm)
Blue Wail is offline
