Heater Hose Delete. Need help. - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 11-11-2014, 10:04 PM Thread Starter
I have a 94 roadmaster with some
Bolt ons that I am setting up for drag strip
And weekend cruiser. I have no ac, and
Now I want to get rid of heater core and
Heater hoses for weight reduction and
Engine bay cleanup. Ok so I could freeze
Plug or even loop a small hose right at
The water pump from the top to bottom
And get rid of them. But do I have to plug
The bottom of the expansion tank? It's a 94
So it has two small outlets on top and the big
One on the bottom. How do I get water in
Radiator if I plug the big outlet which T's
Into the water pump and heater core? If anyone
Has done this can you please guide me. Thanks
So much. Any help is appreciated.
Sleeperbuick is offline
post #2 of 4 (permalink) Old 11-12-2014, 03:49 AM
95wagon's Avatar
Leave the small bleed lines in place
You need to run the large line off the bottom of the surge tank to the inlet hose on the water pump ( same place it goes now )
You can remove the pipe and hose that goes from the pump to restrictor to heater
Remove the hose from heater to surge tank.
So essentially you would be putting an elbow where the "T" is now.
This way the pump is always pulling at the head of water in the surge tank and any air is bleed from the engine to the tank.
This also keeps the rad cap at the lowest pressure of the system
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #3 of 4 (permalink) Old 11-12-2014, 11:04 AM Thread Starter
Thank you very much sir, I appreciate
The help. I
Need to find a freeze plug to tap
It into the where the metal tube is or
Just get a cap. But the cap Will probably
Tear with time.
post #4 of 4 (permalink) Old 11-12-2014, 11:23 AM
Founding Member
Area 51 Perf's Avatar
The help. I
Tear with time.
or just tap it and put a plug in it after you pull out the metal tube.
ECTM#1
East Coast Troublemakers
Disclaimer:
The poster does not take any responsibility for any bad feelings or sense of exclusion that the reader of this post may have-whether real or imagined. Reading threads poses inherent risks. The poster of this thread would like to also remind readers to make sure they have a functional sense of humor and a brain before they visit any discussion board
Area 51 Perf is offline
