dumped - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 01-19-2015, 11:10 AM Thread Starter
Thumbs down dumped
just got another 95ss, had it for about a month now. Drove it to the city Fri and on the way home when I parked the car, all the contents of the reservoir tank dumped out from the tubing that is closest to the windshield, the tube just ran out from the tank and is zip tied to the larger hose, I assume its supposed to go somewhere else? What would cause this to happen and where should that hose go? I haven't drove it since, gonna refill the reservoir and wait to hear from you guys on what to do/look for.
Thanks,
Vin
1995 Impala SS ver 2.0
1991 Caprice Wagon SSold, but not forgotten
91wag95ss is offline
post #2 of 9 (permalink) Old 01-19-2015, 12:41 PM
what "reservoir" are you talking about?
cooling system or windshield washer?
I assume you mean coolant and the hose closest to windshield is heater hose....so it is possible the PO had a leaking heater core and just bypassed it by just connecting the two heater hoses together and whatever that connection "was" it came off and you puked all your coolant
but without a pic just guessing from this side of the internet
post #3 of 9 (permalink) Old 01-20-2015, 05:13 PM Thread Starter
yes the coolant reservoir. Since that tubing is basically running to nowhere right now should I clamp/close it off? Where should it go?
Thanks
post #4 of 9 (permalink) Old 01-20-2015, 09:10 PM
It probably goes to the TB, but you can plug it.
Fred Kiehl is online now
post #5 of 9 (permalink) Old 01-21-2015, 09:33 AM
Dumping coolant
I think that is a 1994 reservoir tank on a 1995 car. On a 94 that hose goes to a fitting on the passenger side of the radiator. That fitting was elimiated in 1995 so the hose should be clamped off. The cooling system will never develop pressure with the hose open.
Ken
Ken Hennessy is offline
post #6 of 9 (permalink) Old 01-22-2015, 11:17 AM Thread Starter
I filled the reservoir coolant tank and drove it about 6 miles. When I got back home I opened the hood and heard gurgling/bubbling coming from the reservoir tank. coolant didn't come out like last time (I having plugged off that line yet) There was some coolant dripping/leaking from the large radiator hose on the passengers side.
post #7 of 9 (permalink) Old 01-24-2015, 12:15 PM Thread Starter
Ive since plugged that opening and bled the air out at the WP and filled up the reservoir again. Drove it around yesterday with no issues. Gonna pick up an AC Delco res cap at the dealer today just in case. I think the drip from my above post was due/from the hose was still hooked into the res.
post #8 of 9 (permalink) Old 01-28-2015, 10:03 PM Thread Starter
I got the ac delco cap for a 95, Is it the same as/for the 94 tank that I have on there?
post #9 of 9 (permalink) Old 01-29-2015, 10:47 AM
it should be a 15 psi cap. 94-95 use the same cap but even a 96 cap will "screw on".
