Replacement Heater Core Quality - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 01-20-2015, 07:26 AM Thread Starter
ocala's Avatar
I blew my head gasket a while back, so I figured the heater core could be contaminated, in addition to being old. Also, I'm putting in a new radiator and hoses. I'm also changing from DexCool to BeCool coolant.
So I figured, why not just put in a new heater core and have a really clean system...
So I pulled my heater core to put in a new one. When I put them side by side, the cheap construction of the new one was obvious.
The new one was the best I could find at RockAuto. The new one didn't even have the support that connects the two outlets. (I moved that from the old one to the new one in the pictures)
It also didn't have the 3 straps that are holding in the sides on the OEM.
Also, the new one doesn't have the raised stops on the tubes to hold it in place against the firewall.
I'm actually thinking of taking my old one to a radiator shop to be reconditioned. If I go this route, what should I ask them to do?
Or does anyone know where I can get a GOOD new one?
I've searched the forum and not really found an answer to this one...
Thanks!
Thoughts?
ocala is offline
post #2 of 6 (permalink) Old 01-21-2015, 02:34 PM
Prestone makes a good flush kit. I would try that and let it soak over night then flush in both directions many times. If you think you can pull the tanks off the side without destroying them the would be an even better flush.
If you take it to a radiator shop just ask them to flush it as they would a normal radiator. Because at the end of the day that's all a heater core is. hth
96 Impala SS
142,989
What does it matter anymore?
02 7.3 drw 350. It pulls really heavy stuff.
2015 Camry xse is my new daily. It has electric steering!!!!
M0U35Y's_SS is offline
post #3 of 6 (permalink) Old 01-21-2015, 07:04 PM
fastfred's Avatar
Arrow Same thing
I think I have the same core on my bench now from Rockauto. The Spectra Premium.
Just haven't installed it yet. How did you like rotating the tubes to match orientation?
Doesn't give me warm feeling.
I do see an Ac Delco on Rockauto now.
Fred SSmidt
95 DCM Long mod list
96 LT-1 Caprice
96 DCM Stock
95 Black Stock
95 9C1 mostly restored
66 Caprice Stock original
66 Impala Project
[email protected]
fastfred is offline
post #4 of 6 (permalink) Old 01-21-2015, 08:47 PM Thread Starter
ocala's Avatar
The one I bought from RockAuto WAS an AC Delco. BS...
I think I'll return it.
ocala is offline
post #5 of 6 (permalink) Old 01-23-2015, 04:54 PM Thread Starter
ocala's Avatar
I'm wondering if anyone has ever tried a 92 Caprice heater core in an impala?
There are a few around, much better quality. I realize there must be SOME difference, but it looks real close...
Thanks
ocala is offline
post #6 of 6 (permalink) Old 10-27-2015, 08:42 PM
udownwitk's Avatar
Send a message via AIM to udownwitk
Thanks
Attachment 107721
did you ever try it?
1996 Impala SS 121K miles: Gen II Tri-Y's, No Cats, Yukon 3.73 w Auburn Pro, bored 52mm TB w/ Air Foil/Bypass, Spintech ProStreet 6000, 8.5mm MSD wires, Delco Plugs, C3Fab Extended Arms, Vogtland springs, Bilsteins, AIR Delete, PCMforless Tune, LT4 KM, Hypertech 160* stat, Viper Alarm, Impala #31,960 Built: 9-13-96
udownwitk is offline
