adding an on/off toggle switch for cooling fan? - Chevy Impala SS Forum
post #1 of 26 (permalink) Old 03-16-2015, 09:08 PM Thread Starter
95DoubleBubble's Avatar
Has anyone ever done this? I use my 95 caprice for work, making deliveries so I am constantly sitting at traffic signals or idling outside of delivery locations. I don't like the high temp setting that these cars come programmed before the fan kicks in, I have heard of having the computer reflashed but this is my only car and I can have it down more then a day. I'm looking for any insight on how I can wire in a toggle switch so I can flip the fan on when in traffic or when at the delivery. I appreciate any help that can be offered.
Phil
95DoubleBubble is offline
post #2 of 26 (permalink) Old 03-16-2015, 10:17 PM
There's a bunch of ways to accomplish this with one,or both fans. Manually grounding the fan(s) relay will cause the fan(s) to come on. The schematic of the underhood fuse center might be helpful,though one should be able to identify the circuit(s) without one...
post #3 of 26 (permalink) Old 03-16-2015, 11:41 PM
Re-flash your PCM for lower temps. There is no need to have your car "down" or to send your PCM anywhere. It's OBD 1. Forget the switch idea.
Jim B.
fbi9c1 is offline
post #4 of 26 (permalink) Old 03-16-2015, 11:43 PM Thread Starter
how do i reflash it? I was under the impression it had to be sent out to a specialty company
post #5 of 26 (permalink) Old 03-17-2015, 12:43 PM
Bugman's Avatar
The problem with a switch is that you will eventually forget to turn it off. If your AC system is in working order, the fans should kick on when you turn on the AC.
Disclaimer: Any hokey-assness on my personal vehicles does not reflect the quality of my work done while I'm on the clock
Bugman is offline
post #6 of 26 (permalink) Old 03-17-2015, 02:34 PM
2 Sweet's Avatar
Are there any drawbacks to this?
I've let people borrow my car before for hours or even days at a time, and I just leave the switch on before they take possession. Easier then telling people to watch the temp gauge and hoping they remember. It's been rigged with a manual switch for over 10 years and never an issue. I would rather have it run cool than worry about letting it overheat
DGGM 1995 Chevrolet Caprice 9C1 LT1
2 Sweet is offline
post #7 of 26 (permalink) Old 03-17-2015, 02:51 PM
Aside from wearing out the fans really quick? Just because they still spin,doesn't mean they're still moving the amount of air they're supposed to. Generally,it's a bad idea to run the fans all the time (unless it's an emergency),but loaning out one's car to others is an even worse idea in my experience. The load the fans place on the electrical system when running constantly is substantial,and likely to overheat wiring,connectors,relays,etc,etc...
post #8 of 26 (permalink) Old 03-17-2015, 03:31 PM
2 Sweet's Avatar
Valid points. I still wouldn't worry about it. Like I said, I've never had a problem. Maybe I'm just lucky? I think as long as you pay attention to your gauges you won't forget to turn it on/off. That being said, a reflash is the best option simply for peace of mind, if nothing else.
2 Sweet is offline
post #9 of 26 (permalink) Old 03-18-2015, 01:22 PM Thread Starter
So how do I go about reprograming?
post #10 of 26 (permalink) Old 03-18-2015, 01:29 PM
350
350's Avatar
Send a message via AIM to 350
My car has a switch, no clue how it's wired though because it was there when I bought the car. It doesn't override the PCM, it just allows you to turn the fans on manually at any time, ie staging lanes for drag racing. Still a good idea to have the PCM retuned for fans and a bunch of other things. Pick your mail order tune of choice or maybe hit up Nab (Blue Wail) if you're near him in MD.
95 DGGM SS. Cam and headers, boring stuff, classic tags, garaged
15 Durango R/T AWD, Fiat with a Hemi and 8 gears
15 Charger SXT AWD
350 is offline
