New GM compressor source? - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 06-26-2015, 07:34 AM Thread Starter
Toms9C1's Avatar
Looking for a New compressor recommendation, the good, the bad and the ugly. Having mine done as I speak, $480 for a Delphi unit, ouch! Can we find one less expensive for my fleet for the next time around?
Tom
ISSCA Member #2540
95 B4U: LT4 LE Cam 1.6 RR Eibachs 17" SS Whls K&N XPypes Mech fan delete+Gary's wiring harness RM Lthr seats Imp SS Rear Disc Eaton Posi Motive 3:73's Moser Axles Stainless brake lines NEW 4L60E/Dacco 2000
94 9C1: Eaton Posi 3:08's XPypes Stainless Brake lines
95 L99 DCM: SS Clone Vogtland springs Monroe SS shocks XPypes Front end overhaul w/Alum bushings
96 RMW Woody Black / Red guts
http://badass-of-ne.forumotion.com/forum.htm
Toms9C1 is offline
post #2 of 10 (permalink) Old 06-26-2015, 07:37 AM Thread Starter
Toms9C1's Avatar
Anyone use this one? http://www.gmpartsoutlet.net/chevrol...ame=compressor
Tom
ISSCA Member #2540
Toms9C1 is offline
post #3 of 10 (permalink) Old 06-26-2015, 07:44 AM
juniorwatson's Avatar
I got mine locally out of Austin back around 2009, and I can't seem to find the receipt for the MFG or P/N. That said, the unit was only approximately $225, and it's been working great.
I actually just fired up the car and the system after the car had been in storage for a few years, and the A/C still works like a charm.
When I was piecing together parts for my system, I used this place.
AC Kits.Com
They've got two compressors priced rather inexpensively @ $169 & $257 right now.
juniorwatson is offline
post #4 of 10 (permalink) Old 06-26-2015, 07:48 AM
Originally Posted by Toms9C1 View Post
I have not. I know that the web site GM Parts Direct, is just a website for a dealership, and it has nothing to do with GM.
For $hits and giggles, if you'd like to price a Delphi unit, I'd shoot Mike @ Hamilton Chevy a PM and see what his pricing is.
Otherwise, I'd suggest going with an aftermarket, as I've been extremely happy that my system puts out damn near freezing temperature air at the vents (32'-34').
post #5 of 10 (permalink) Old 06-26-2015, 09:51 AM
http://www.northernautoparts.com/Pro...nSubmit=Search
$200 at Northern Auto parts, includes drier.
JackFish is offline
post #6 of 10 (permalink) Old 06-26-2015, 08:09 PM
ghetto wagon's Avatar
New compressors are all made in China these days + probably are cheaper quality than factory ever was. It does not really matter of the brand, they are all made in the same Chinese factory. Blame chinese parts on the US govt GM bailout. I Never liked the Denso/ Delphi compressor clutch, it looks funny too.
Car still works MOD
ghetto wagon is offline
post #7 of 10 (permalink) Old 06-26-2015, 10:17 PM
TGO
Not knowing I could get the stock GM compressor rebuilt, I took my car to my local shop and had them replace it with an aftermarket unit. It blew up after about a week. Literally blew up. I turned the AC on one day and my car suddenly looked like a steam locomotive. It blew a chunk off the back of the compressor where the lines attach.
They replaced it and so far, no more problems.
But my butt hole still puckers whenever I turn it on, because the warranty is up.
TGO is offline
post #8 of 10 (permalink) Old 06-26-2015, 11:16 PM
This truck I was driving for a few years, it blew up 6 compressors in a row, cheapest of the cheap chinese compressor was put on. I have a AC delco Made in mexico of imported parts compressor waiting to put on, seems to be nice, I have all the parts and tools it just needs to cool off here!
Yes you can rebuild the factory compressor I want to take apart mine, Basically the case O rings are prone to leaking as is is the shaft seal, if it was working ok and was quiet, if you reseal it it should be good to go.
Car still works MOD
post #9 of 10 (permalink) Old 06-27-2015, 06:07 PM Thread Starter
Toms9C1's Avatar
When he told me the price I said this thing better be able to make a good cup of coffee too! lol! So it sounds like a flip of a coin where it gets built, how long it lasts. We'll see what happens.
Tom
ISSCA Member #2540
Toms9C1 is offline
post #10 of 10 (permalink) Old 07-05-2015, 01:04 PM
The Delphi unit is one of the best made I have seen. I put two on last year, for a couple of friends. Better quality than the Four Seasons crap at Advance and also seemed to be better than the OEM (Delco).
Alchemist is offline
