drop out of WP weep hole - parts to get - Chevy Impala SS Forum
post #1 of 15 (permalink) Old 07-07-2015, 08:41 PM Thread Starter
I'm probably looking at a new WP for my SS - my rebuilt motor just started leaking a bit of water around the WP weep hole. Just a drop but will likely get worse. It was new back in 2003 but recently sat for a couple years and the seals probably got brittle.
I've done this on my RMW.
Question is, if you buy a new WP (likely will get Gates -good luck with those), i know you get the one (maybe two??) little WP seal(s) for the drive shaft and two gaskets. You can buy Felpro TCS45956 to get the engine/Opti seal, the WP seal, and the front crankshaft seal. How about the Opti o-rings. Do they come with the Felpro set? I see two o-rings but are they the WP o-rings or the Opti o-rings?
Now the big question: you can't get 'new' opti's anymore that are GM. Is Delphi now the preferred brand? Cardone Select (lifetime warranty)?
Alchemist is offline
post #2 of 15 (permalink) Old 07-08-2015, 01:40 AM
Why are you replacing the opti?
Jim B.
fbi9c1 is offline
post #3 of 15 (permalink) Old 07-08-2015, 05:30 AM Thread Starter
Yeah, I know, why replace a working Opti. It's at least 12 years old, and thinking it would be best at this point. But it's big $.
post #4 of 15 (permalink) Old 07-08-2015, 07:03 AM
1BAD9cONE's Avatar
If you get a new opti you want to get AC Delco
Kyle Wiltse
"BIG DADDY"
1BAD9C1
SSin City SS - V.P.
1BAD9cONE is offline
post #5 of 15 (permalink) Old 07-08-2015, 07:05 AM Thread Starter
I've heard there are no more 'new' opti's, that all are actually reman'd, from AC Delco. How does everyone feel about the Delphi unit, CZ20003?
post #6 of 15 (permalink) Old 07-08-2015, 07:35 AM
I suppose the Delphi is okay. Myself,and many others are still going to prefer the AC Delco. Why even bother with a perfectly functioning opti to begin with? I sure wouldn't...
post #7 of 15 (permalink) Old 07-08-2015, 08:00 AM Thread Starter
I hear you on the opti. I do get a very low throttle jerk, almost a miss, that I wonder might be attributable to the opti, rotor, or cap. On the 95, the OBD1 doesn't give a misfire code, but one time, when leaving work, it jerked very bad and threw a code, but it went out immediately. I need to read what it was, in my history. I know you can replace the cap and rotor and that might be preferred.
post #8 of 15 (permalink) Old 07-08-2015, 10:10 AM
angelo's Avatar
Thumbs up
When i did mine....
https://www.impalassforum.com/vBullet...d.php?t=243202
I got the kit
http://s101.photobucket.com/user/jod...006-7.jpg.html
but I only did the WP, so if i remember right you need more o-rings... I did not buy any other parts.
AFA the jerking....is it a jerk or more of a slight miss?
My car on roads with a slight incline, and i am idling and creeping up, if i very lightly tap the go-pedal i can
make the engine sort of stutter if you will, but i've been told that is the EGR hunting between open and closed...?
Figured I'd throw that out there in case you may have nothing to fix.......
My SS runs fine, this is a specific repeatable set of conditions that are present to make my car stumble...
Good Luck with the WP...mine is still running fine.
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #9 of 15 (permalink) Old 07-08-2015, 10:16 AM Thread Starter
[QUOTE
Fine SS runs fine, this is a specific repeatable set of conditions that are present to make my car stumble...
-ALF out...[/QUOTE]
It's a little of both - a miss and the car is 'jerky' at lower idle in each gear. If I'm above 2000, smooth. I have no EGR, never have, as the LT4 intake and my cam don't require it (that is completely legal).
post #10 of 15 (permalink) Old 07-08-2015, 01:17 PM
I would suggest that you not change the OEM opti. Just change the cap and rotor to an MSD set. It's a lot cheaper and works great. I have 20years and 395,000 on my original opti with MSD cap and rotor and it still works fine. Use the money you save for other maintenance items that actually will need attention. Your hesitation is not a symptom of a bad opti. Look at the EGR, fuel filter, plug wires.
Jim B.
fbi9c1 is offline
