Water? On the carpet floor under the glove box - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 07-21-2015, 01:31 PM Thread Starter
Unhappy Water? On the carpet floor under the glove box
Last year my heater core took a dump so I disconnected the hose under the hood and bypassed the heater core.
A couple of weeks ago my radiator low fluid light came on, so I added coolant. I was surprised because I just had the water pump changed last year (full tune up). I haven't had any issues until then. She doesn't overheat.
Last night I noticed the carpet under the glove box section was very damp/wet (as if a heater core was bad and leaking)
It's been humid out here in California and I've been running the AC a lot. I'll start researching but maybe someone can point me in the right direction.
White '95 Stock 9C1
Tan cloth interior
5150 9C1 is offline
post #2 of 13 (permalink) Old 07-21-2015, 01:41 PM
juniorwatson's Avatar
From your description of using the A/C recently, it sounds like the 90' elbow may have come off the outlet on the firewall that directs the sweat from the evaporator core down and away from the firewall.
If this is missing, it's been known to let the water inside the cabin, and cause a wet carpet issue.
Does the carpet area have any odor to it?
I think I have a photo on my online bucket account, let me see what I can find so you can clearly understand what I'm writing.
juniorwatson is offline
post #3 of 13 (permalink) Old 07-21-2015, 01:44 PM
poppa's Avatar
Check the drain hose on the A/C blower housing you will find it located on the passenger side in the engine compartment . Make sure it is clear and you can also flush out the housing there using compressed air. If it is very humid the A/C coils may have frozen and temporarily blocked the vent causing the condensation to back up in the cab. You can dry the carpet out with a coin op wet or dry vac at a car wash. Good luck.
The Rev'in Mr. Black Powered by a 383 stroker with 10.5-1 J&E pistons, Eagle rods and crank. GM aluminium angle plug heads, Lt 4 hot cam and 1.6-1 roller rockers. K&N Intake and Cat delete Export pipes with Hooker 2.5 exhaust. built 4L60E trans with trans-go kit, kevlar clutches and corvette servos 2400 rpm stall converter with 3.42 gears. 96 Floor shift console, van roof console and T-84 glass headlights.
http://s1256.photobucket.com/albums/...IM000157-1.jpg
poppa is offline
post #4 of 13 (permalink) Old 07-21-2015, 01:57 PM
Here's a closeup of the bottom half of the cover for the evaporator core with the outlet that sticks thru the firewall:
Here's a picture of the elbow that I inserted and RTVd a piece of tubing approximately 2' long that is tied to the frame, that directs the water from running down the firewall. The tubing inside is cut @ a 45' angle so there is no obstructing the water coming out of the drain tube from the lower cover:
Let us know how you make out.
post #5 of 13 (permalink) Old 07-21-2015, 01:59 PM Thread Starter
Thank you JuniorWatson and Poppa. I'll get on it this weekend and follow up with my findings.
White '95 Stock 9C1
Tan cloth interior
5150 9C1 is offline
post #6 of 13 (permalink) Old 07-21-2015, 02:38 PM
As others have mentioned, this is a common problem on our cars. The little Elbow usually falls off and just search "wet Carpet" and see all the hits you find here. I believe the QaloSS Handbook also touches on this issue. You may still be able to source the standard elbow from the Dealer or online and use a "little" RTV to hold it on there. Careful not to block the opening with RTV though.
However, if you want to do something a little different and keep all that condensation from dripping on the car, just use a long length of hose with a 90* elbow in it. I had an old 9C1 Heater Hose that faded really bad and was going to trash it....this is why I never throw stuff away. Instead I just used it on the Firewall fitting and ran it down below the frame. You will see it pictured in the last post of this thread to give you an idea of what I'm referring to.
https://www.impalassforum.com/vBullet...ght=wet+carpet
post #7 of 13 (permalink) Old 07-21-2015, 06:40 PM
A piece of 5/8 i.d. clear tubing and a small worm clamp will work fine. Take a zip tie and direct it under the car and cut it at the proper length. It's a permanent fix that works better than replacing the original elbow. Replace you heater core while you are at it. It's not like it costs a fortune or is a big job.
Jim B.
fbi9c1 is offline
post #8 of 13 (permalink) Old 07-22-2015, 12:14 PM
Did yous get rain down there? If it's rain water, search threads on the cowl leaks and how to fix them. I had that problem and fixed it.
God Bless America!
1996 Impala SS DCM
1996 Impala SS BBB
1995 Buick Roadmaster Sedan
2014 Chevrolet VOLT
2016 Chevrolet Cruze
1986 Corvette Coupe
1988 Lincoln Mark VII LSC
1986 Ford F250 6.9 Diesel 4x4
Mikeceli is offline
post #9 of 13 (permalink) Old 07-22-2015, 04:11 PM
93capriceltz's Avatar
I'm going to try the curved 9C1 hose. That's a great idea! I can see where it can help too. All of the B Bodies I've had have had this issue to one extent or another, especially when driven aggressively.
1993 Caprice LTZ / LS:
51,000 miles, L05, 3:08 Posi, Harris Prom, Lowering Springs, Bilsteins,
96 Steering Wheel, 9C1 Hoses, Dual Snorkel Intake,
SS Rear Disks, J55 Fronts, High Flow Cats, Dual Exhuast, Fleetwood Horns and Center Console, Roadmaster Rear Door Lights, LED Interior
1992 Caprice Wagon: Black Sapphire/Silver, L05, Tow Pack, 3:23 Posi, 9C1 Cluster, 96 Steering Wheel, Fleetwood Horns, LED Interior
1996 9C1 - Former Whelen Trade Show Car - SOLD
1994 SS - SOLD
1991 9C1 - SOLD
93capriceltz is offline
post #10 of 13 (permalink) Old 07-22-2015, 04:44 PM
It does a good job of diverting the water to the ground. The FW port in my opinion is not the best thought out location to have it drain. You don't need to cut up a 9c1 heater hose, that's just what I had on hand and it was a weird color.
Any 5/8" inch hose with a 90* bend will work and just cut the 1 end short and leave the other side long. A length of some Black Heater hose would be a little more stealthy. Whatever you choose, it is important to get a clamp on there so you don't loose it.
