96 Caprice Blower Motor R/R - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 08-15-2015, 09:19 PM Thread Starter
Think the blower motor is going out. Runs fast and slow when set on high. Sometimes it won't run at all. If I get under the dash and move the plug to the fan then the motor comes back on. How hard is it to replace?
MS
First Born: 1996 Chevrolet Caprice Classic. Blue
Second Born: 1984 Chevrolet G20 Conversion Van. 1980's three tone brown paint scheme.
Red Headed Step Child: 1989 GMC Suburban 4X4
But the family is still growing.
Duesyj29 is offline
post #2 of 5 (permalink) Old 08-16-2015, 10:53 AM
The fan replacement is fairly simple. You have to remove the door sill, and the kick panel. Remove the insulator panel under the dash. The motor is held in by three 5.5mm screws. You may have to push some wire bundles out of the way to remove the fan. The new fans are 3/16" shorter than the OEM ones, and will put out less air,, because of bleed-by. A good used one will often be a better option. While you are under there, an inexpensive resistor module is good insurance against having to get back under it again. Four 5.5mm screws hold it in place. I would get some liquid insulation, and paint the bottom 1/2" of the wires/connectors on the resistors.
It may be just the resistor module as well. I would try that first, and you may not have to buy a fan.
post #3 of 5 (permalink) Old 08-16-2015, 01:36 PM Thread Starter
Do you have pictures of the blower motor resistor module? That way I know exactly what I'm looking at.
MS
Duesyj29 is offline
post #4 of 5 (permalink) Old 08-16-2015, 01:55 PM
MS
This seems to be a pretty good video showing location....
https://m.youtube.com/watch?v=UT8cwed8F_M
post #5 of 5 (permalink) Old 08-16-2015, 04:49 PM Thread Starter
Thanks for the video. That helped quite a bit. I got the motor replaced, turns out the resistor module is fine so I'll be taking that back for a refund.
Thanks again,
MS
Duesyj29 is offline
