is coolant reservoir made of polyethylene ? - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 09-15-2015, 01:13 PM Thread Starter
angelo's Avatar
what kind of plastic is the res made of, anyone know ?
Or is it
polypropylene ?
i am going to test maybe using plastic welding strips to see if i can fix one that is cracked along the seem.
thanx.
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #2 of 9 (permalink) Old 09-15-2015, 02:32 PM
Take it off and look it over. There should be a marking indicating the material. Hopefully it's not molded on one of the non-visible interior surfaces.
It will likely look something along the lines of >PP<. The letters will denote the material.
threeimpalas is offline
post #3 of 9 (permalink) Old 09-16-2015, 07:44 PM Thread Starter
angelo's Avatar
Yup i checked my spare...it's PP = polypropylene
gonna see if they sell strips of that stuff now.
-ALF out...
angelo is offline
post #4 of 9 (permalink) Old 09-18-2015, 06:33 PM
If you can not find the sticks, any piece of polypropylene will work for filler.
post #5 of 9 (permalink) Old 11-16-2015, 01:58 PM Thread Starter
angelo's Avatar
Thumbs up Did a repair, need to test it...
Finally got around to this last weekend.
Not sure when I'll get around to installing it for a test, today was 60 degrees and likely the last warm day til spring.
Here is link to all the picks on cardomain.com
http://www.cardomain.com/ridepost/63...vrolet-impala/
here are the Cliffs....
Tools
Setup
First timer at plastic...
Some are better than others.
-ALF out...
CLICK ME !!!
angelo is offline
post #6 of 9 (permalink) Old 11-17-2015, 12:49 AM
Well, at least you've got more than enough rationale to spray that whole ugly mess gloss black now.
Seriously man, good work - and write-up. Just a question: did the crack come from excessive (>15#) pressure, or just look like a manuf. flub?
post #7 of 9 (permalink) Old 11-17-2015, 10:28 AM Thread Starter
angelo's Avatar
I think it's a manu flub........
i leaks at the seam where the two halfs are melted together when the thing is made.
It only leaked in 2 spots, but i am not doing this again so plastic welded almost the entire
tank.
-ALF out...
angelo is offline
post #8 of 9 (permalink) Old 11-17-2015, 10:42 AM
Nice work, I've thought about getting one of those Harbor Freight kits for a while now. Be interested to hear how the repair holds up once you get it back on the car. But the Green is not too purty. I guess the HF kit just uses dye in the rods so you can tell the difference in plastic types.
FYI - Was curious to see if the PP rods were available elsewhere in other colors and it appears like they are. Just found this link and appears to be a better color match. You may not need that many and could maybe find less expensive options out there to match.
https://www.interstateplastics.com/P...FZUlgQod5dUESQ
post #9 of 9 (permalink) Old 02-01-2016, 07:25 PM Thread Starter
angelo's Avatar
Swing and i miss...
Well, so much for only doing this once.
My mech pressure tested it and i still have one leak.
It's marked with the black "x" 's .
Maybe next month will have time to weld the rest of it up.
-ALF out.....
CLICK ME !!!
angelo is offline
