All-aluminum radiator only $65 new - Chevy Impala SS Forum
post #1 of 27 (permalink) Old 09-29-2015, 08:24 PM Thread Starter
Blue Wail's Avatar
I found this gem the other day and ordered one.
It's no mistake... for now....
http://www.shepherdautoparts.com/all...rice/1995.html
Nab
April's Sparkle Cat
383 LT1 12:1 flat top + 75 shot
11.66 @ 117 at SSHS17 Nov 11, 2017
2017 12.0 Index Champion
4140 lbs. w/ driver. front sway bar ON
Powered by 4L80E! (controlled by LT1 pcm)
Blue Wail is offline
post #2 of 27 (permalink) Old 09-29-2015, 09:36 PM
Erik's Avatar
Nice. Any idea what the difference is between the two models? Which one for a '96 SS?
Nodding Tiger Mod
https://www.impalassforum.com/vBulletin/image.php?type=sigpic&userid=15034&dateline=1214775786
Erik is offline
post #3 of 27 (permalink) Old 09-30-2015, 05:46 AM
Nab
That is a Great price, you would almost expect a "1" to be in front of the number in the price. I wonder if that is a mistake on their part...I don't need one but at that price I'd be crazy not to at least order one. The Silla aluminum rads were about twice as much.
Just for shyts and gigs I checked the rads out for a 70 Monte Carlo and a 70's Camaro. Both were either 2 or 3 core and the pricing was still around $65. So maybe their pricing on these is just really cheap....hope the part is not built cheap.
Based on what I saw in the pics.....they both have the transmission cooler but if you look on the left side, only 1 has the engine oil cooler built in. So one could be for the impala with engine oil cooler and the other could be for a 9c1 car or someone running the external oil cooler. But based on my findings with the stock rads, either rad will fit in the car if you wish to add the oil cooler later, you got the internal cooler if you want it. If you don't want to use it, just block off the 2 ports.
post #4 of 27 (permalink) Old 09-30-2015, 06:43 AM Thread Starter
Blue Wail's Avatar
The one with both the tranny cooler and oil cooler is for an SS.
If you have an external engine oil cooler get the other one.
Forgot to mention... this IS the Silla radiator by the way
Sad part is I bought my first one of these a couple months ago off
of Amazon from the same company and paid $150!!!
Nab
April's Sparkle Cat
post #5 of 27 (permalink) Old 09-30-2015, 06:44 AM
SEO9C1's Avatar
Great deal Nab! Those are Silla rads. A couple years back, I picked up the 2 row for about $30 more. Has been in since and never had any issues w/ it.
SEO9C1 is offline
post #6 of 27 (permalink) Old 09-30-2015, 09:24 AM
angelo's Avatar
Only thing i see missing is you need to transfer your mounting brackets for the electrical fans, from old RAD to new one, if you have a stock SS....
Nice find Nab !!!
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #7 of 27 (permalink) Old 09-30-2015, 09:42 AM
Mr pogo's Avatar
ditto on the great deal!
they also have the ac condensor at $30.
Mr pogo is offline
post #8 of 27 (permalink) Old 09-30-2015, 10:10 AM
B1BADSS's Avatar
Nice find!!
- Arneil
"It's Me BitcheSS"
SSin City SS / ISSCA 1731 / HERD 777
96 Impala SS LT1 383 (B1BADSS)
96 Impala SS LSX 6.0 (BADLSX)
07 300C SRT8 (VN1525)
B1BADSS is offline
post #9 of 27 (permalink) Old 09-30-2015, 10:40 AM
Erik's Avatar
Got one on the way. Thanks nab.
Nodding Tiger Mod
Erik is offline
post #10 of 27 (permalink) Old 10-01-2015, 05:18 PM
Got mine today - 24 hours after ordering it! LA to San Diego via FedEx for $10. Thanks for the heads up on this OP.
May or may not keep it.
2 issues.
They list 2396AA for all 94 - 96. But only 94 has the nipple to the reservoir. I use a later 96 reservoir and didn't notice in the pic. So their website is not quite correct. I always order for 96 Caprice because so many part houses don't recognize Impala or Roadmaster. Most other replacement radiators are 95 - 95 type without nipple. Really don't like that. I can block it off like previous original but don't like the look.
And the petcock was messed up. I could replace with another but why should I have to.
For the bargain price it is probably excellent value - adequate but somewhat rough soldering in places.
EDIT: Check the link below. The 2395AA (without oil cooler) has the correct side tank without nipple as on stock 95 and 96.
I will contact Shepherd and see what they say.
grandpas wagon
grandpas wagon is offline
