engine mounted fan on LT1? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 11-04-2015, 02:09 PM Thread Starter
95DoubleBubble's Avatar
Is it possible to do this or does it only work on the 93 and older cars? My buddy put one on his 93 fleetwood that he pulled off an old cop car but i know the 93 is a different motor.
95DoubleBubble is offline
post #2 of 3 (permalink) Old 11-04-2015, 02:14 PM
I picked up an LT1 from a '95 Roadmaster and it had a clutch fan.
JackFish is offline
post #3 of 3 (permalink) Old 11-04-2015, 02:59 PM
Some LT1's came with this setup and think this is the HD Cooling option. This article has some info in there about this Clutch driven fan.
http://garage.grumpysperformance.com...ing-info.2538/
There are some parts/brackets/belts/etc you would need to pickup if this was something you were serious about. Most usually convert from this to electrical so you may have luck finding parts. Finding a donor that you remove yourself would be ideal since you could note how it installs and grab all you need.
