What are the part numbers for the radiator fan motors? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 11-15-2015, 11:41 AM Thread Starter
About to replace the primary [150Watt] and 2ndary [240Watt] radiator fan motors, but I need the part numbers for them.
Anyone know what they are?
150 Watt Primary [Passenger-side] Fan Motor #15-8498
240 Watt 2ndary [Driver-side] Fan Motor #15-8490
Thanks!
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
post #2 of 3 (permalink) Old 11-15-2015, 02:02 PM
Mr pogo's Avatar
MOTOR KIT,ENG CLG FAN(ACDelco #15-8490) - LH
MOTOR KIT,ENG CLG FAN(ACDelco #15-8498) - RH
Mr pogo is offline
post #3 of 3 (permalink) Old 07-19-2016, 11:06 AM Thread Starter
As a precaution, I find it necessary to ask for the part number of the 100Watt 2ndary fan, if only to specifically AVOID its use [in favor of using the 240Watt 2ndary]?
