heater core 'extra part' question? - Chevy Impala SS Forum
post #1 of 1 (permalink) Old 11-18-2015, 06:16 AM Thread Starter
OK, in buttoning everything back up for my 96 Buick Roadmaster heater core, which works nicely now, I found this eight sided steel 'spacer' with a simple hole in the middle (no threads). I'm thinking it could be a spacer for the underdash steel brace that supports the lower dash to the firewall. See the pictures. The last two are with the brace over the 'spacer'. There's a bit of rust on one side of the spacer, and on that same side there's a traceout of what appears to be same shape as the brace end.
Any of you that have done this recently recognize this part? Does it go anywhere familiar?
Alchemist is offline
