AC evaporator core 'seal' - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 11-18-2015, 06:18 AM Thread Starter
Somehow on my 96 RMW, I managed to remove the brace for the evap core and in doing so dislodged the evaporator core seal (the evap core dropped down a bit). It was nearly disintegrating near the junction of the heater core cover so I removed a two inch strip down on the bottom run. Any repercussion with doing this?
Thanks,
robert
Alchemist is offline
post #2 of 4 (permalink) Old 11-19-2015, 07:28 AM
Are you referring to the insulation around the hose?
post #3 of 4 (permalink) Old 11-19-2015, 07:44 AM Thread Starter
No, This is the foam insulation around the frame of the AC evap core. It's on the right side of the evaporator. I don't really think it matters, but it had dropped down and deteriorated in such a way that it was causing problems of sealing my heater core cover to the box. I just ripped off the 2-3 inch piece that was offending...
post #4 of 4 (permalink) Old 11-19-2015, 09:14 AM
I do not know if it will affect the operation of the AC system, but GM put it there for a reason. You can probably get a good one from a junk yard car if you need it.
