Transmission fluid fitting damaged!!!! - Chevy Impala SS Forum
post #1 of 41 (permalink) Old 01-26-2016, 02:08 PM Thread Starter
xander_ss's Avatar
So today I was changing out my radiator when disconnecting the lines everything went smooth until I got to the transmission lines the fitting was so rusted that it would not spin when I was trying to unscreward the line when it turned it turned the line also so long story short the metal line twisted up it was the only way to get the damn line of the radiator so now I have to fix the line any ideas from you guys would be so helpful or should I purchase new lines I couldn't even find em on line I jus say repair kits
xander_ss is offline
post #2 of 41 (permalink) Old 01-26-2016, 02:38 PM
What year, make and model vehicle do you have?
Mike--Hamilton Chevy
Hamilton Chevrolet is offline
post #3 of 41 (permalink) Old 01-26-2016, 02:41 PM Thread Starter
xander_ss's Avatar
I'm in a 95 ss impala Lt1 350
post #4 of 41 (permalink) Old 01-26-2016, 02:41 PM
OK is it the upper line or the lower line that you broke?
post #5 of 41 (permalink) Old 01-26-2016, 02:46 PM Thread Starter
xander_ss's Avatar
Lower I believe it's on the passenger side above the bigger hose on the bottom
post #6 of 41 (permalink) Old 01-26-2016, 02:48 PM
Bummer. You may want to try to replace just the end but here is the line if you want to buy the whole thing. That is the most expensive line of them all.
http://www.ebay.com/itm/9C1-Caprice-...e=STRK:MESE:IT
post #7 of 41 (permalink) Old 01-26-2016, 02:53 PM Thread Starter
xander_ss's Avatar
Ok thanks man I appreciate the help I'll have to look into trying to repair the hose not sure how to do that
post #8 of 41 (permalink) Old 01-26-2016, 02:56 PM
You would need to get a new section of metal line the correct size and then bend it to replace the damaged section and then flair the end of the new section and the original section in an area that is straight and connect them together and then reconnect to the radiator. Not hard if you have the right tools for flaring and bending.
post #9 of 41 (permalink) Old 01-26-2016, 02:59 PM Thread Starter
xander_ss's Avatar
Well let the repair job begin then lol
post #10 of 41 (permalink) Old 01-26-2016, 03:18 PM
Woah! Over a C note on that tube! If you ain't fubered any portion of seal to the tank I'd say a perfect time to consider a cheap external cooler. Cheaper fix, and better for the fluid too? Justathought.
