Thermostats. - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 03-04-2016, 09:56 PM Thread Starter
punkroqgearhead88's Avatar
Thermostats.
Wondering if I'm the only one having bad luck with thermostats lately?
I've had 2 of the "Failsafe" 160 thermostats fail in the open position not long after I installed them and the latest one was one of the Duralast 160 thermostats (which I've read are actually made by Hypertech) that lasted longer but stilled failed,except shut! Luckily I noticed it before the engine overheated!
Also had another Duralast thermostat on my daily driver F150 fail shut as well.
I have since installed a genuine Motorcraft thermostat in the daily with many miles and no problems.
I would go the same route with the Impala however it has higher than stock compression and it's tuned for a 160 thermostat.
Changing thermostats and having to bleed the cooling system each time is getting old!
Anybody successfully run a restrictor?
Got too much time, work and ca$h invested in my engine to risk overheating.
Mods:58mm Throttle body,Ported intake manifold,Ford SVO 30 LB. injectors,Scorpion 1.6 SA Roller Rockers,Ported 643 casting F-Body aluminum heads,F-Body MAF,Victor Reinz .026" head gasket,LT4 knock module,LT4 Hot Cam,Summit electric water pump, MSD box & wires True Cold Air Intake,Underdrive Pulley,Edelbrock Shorty Headers,9.5" 3000 Stall Converter
punkroqgearhead88 is offline
post #2 of 8 (permalink) Old 03-05-2016, 07:45 AM
kiefer9699's Avatar
My brother and I both run 160 Hyper techs in my 96 BBB and his 95 Firehawk with no issues whatsoever. Now I have had alot of bad luck with Thermostats from Parts stores.
1996 BBB, K&N Intake, FB/HP Delete, AIR Delete,Billet Resonator Insert, TB Bypass, TPIS Air Foil, F Body EGR, Moroso 8mm Wires, NGK Iridium Plugs, HT 160 Thermostat, Magnaflow Hi Flow Stainless Cats, Pypes 2.5" X-Pipe, Dynomax VT Mufflers, Dynomax 2.5" Tail Pipes, KYB Shocks. BMR 1 1/4" Front Sway Bar, Rear GM Upgraded Lower Control Arms, Nitto 450s, PCM4Less 93 tune, Oil Cooler Delete.
kiefer9699 is offline
post #3 of 8 (permalink) Old 03-05-2016, 11:38 AM
FWIW I have run a "hypertech" 160 stat for 17 years. several years ago it was not opening all the way so I replaced it with another hyper. all good
Hypertech, like any other stat, can fail also.
I notice most auto part store "brand" stuff is made off shore....quality often sketchy. Don't know if Hypertech is made off shore as the box does not say "made in" but does have Memphis, TN on the box.
post #4 of 8 (permalink) Old 03-05-2016, 12:39 PM
Yes, I have had the Hypertech 1008 160 stat for 10 years with no issues and replaced it with another one when we did the radiator last year. The Hypertech is also sold as MotorRad, but I don't know the MotorRad part #.
Jim B.
fbi9c1 is offline
post #5 of 8 (permalink) Old 03-05-2016, 02:19 PM
That's odd that you have multiple tstats failing that much. The fail safe ones fail in an open position which won't overheat but takes a while to heat up coolant. Did you flush out the cooling system lately? Maybe a good idea anyway, but could it be that crud is causing them to fail?
I believe the AZ stats are made by motor-rad and just in a Duralast box. Think the same is true in the hyper tech. It should have Motorad and Germany embossed on the body of the stat. I run the AZ unit in my car after a FULL FLUSH and it's been fine for a while now.
post #6 of 8 (permalink) Old 03-05-2016, 04:35 PM
Mr pogo's Avatar
running the duralast motorad with no issues for a few years, a hypertech before that which I replaced because it was old.
this was accurate as of 2012.
https://www.impalassforum.com/vBullet...71&postcount=5
Mr pogo is offline
post #7 of 8 (permalink) Old 03-06-2016, 03:05 PM Thread Starter
Yep. (Pic taken from from Mr. Pogo's link).
post #8 of 8 (permalink) Old 03-06-2016, 03:11 PM Thread Starter
Yes it is very odd, I'm not know to have the best luck.
There is absolutely without a doubt no "crud" in either cooling system of the Impala or the daily. I am religious on maitenance.
