Heater hose clamps - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 04-07-2016, 05:44 PM Thread Starter
Heater hose clamps
I'm changing the heater hose in my 96 Impala today. The way the hose clamps at the heater core were clocked to approx. 4:00 made it impossible to get any sort of tool on them (including the fancy remote cable gizmo) to get them off. I finally had to dremel them off to get the hoses off. Anyone else experience this? Was there a less drastic solution? I'm going to use screw clamps clocked more accessibly when I put it back together tomorrow.
VAXcat is offline
post #2 of 5 (permalink) Old 04-07-2016, 11:43 PM
4x4high's Avatar
I just used my Matco flexible hose clamp pliers and was able to get mine off without any issues.
1996 DGGM Impala SS
4x4high is offline
post #3 of 5 (permalink) Old 04-08-2016, 02:07 AM
I too had to Dremel some OE heater hose clamps.
God Bless America!
1996 Impala SS DCM
1996 Impala SS BBB
1995 Buick Roadmaster Sedan
2014 Chevrolet VOLT
2016 Chevrolet Cruze
1986 Corvette Coupe
1988 Lincoln Mark VII LSC
1986 Ford F250 6.9 Diesel 4x4
Mikeceli is offline
post #4 of 5 (permalink) Old 04-08-2016, 02:21 AM
Brick B-Body's Avatar
I used the 16" long reach pliers from Harbor Freight: 16" Long Reach Pliers Set
At the time, my wagon was 16 years old with 100% GM factory installed cooling system hardware: hoses, clamps, heater core, etc. No problem using the Harbor Freight pliers to squeeze the factory spring clamps and slide them clear of the fitting.
Joel R. Rojas
Region of DOOM
ISSCA # 517
Brick B-Body is offline
post #5 of 5 (permalink) Old 04-08-2016, 06:33 AM
Sometimes it's just about getting a little extra room in there to work and maneuver your hands/tools. Those stock clamps aren't fun, but it may have helped if you removed the 3 bolts to the wiper motor so you could finagle that around a little and get some extra space there.
The worm gear clamps will make your life much easier to install or the next time they need removed. Try to clock the clamp screw so that you can get a 1/4" rachet/extension in there and believe most of the clamp screws are 5/16" head.
