Radiator and A-arm shields templates??? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 08-17-2016, 07:32 AM Thread Starter
Would anybody have made a template for the flexible radiator (condenser) shields that christmas tree to the radiator support? And also the shields that attach to the inner fenders. Mine are long gone, and I see that they are a discontinued part.
Thanks
Todd
95 RMW, 2 1/2 Pypes X, Dynomax VTs, CIA Tri-Y\'s and hook up pipes, swisscheese airbox, TB bypass, airpump del, EGR delete, herter tune, 160 T-stat, Ported F-car Alums with LS2 Beehives and Crane Gold 1.6RRs, GMPP 845, 3.73s, 3200 Vigilante, Trans Go Kit, mech fan del, 34mm front bar, 21mm Ford rear bar, monroe SS shocks, ZQ8 jounce bumpers, poly bushings all around, cop car body mounts, Taylor 8mm, AutoLite Iridiums,
[email protected] ??.? ?.?? 60\'
reaboy is offline
post #2 of 3 (permalink) Old 08-17-2016, 08:08 AM
They are Re-popped by a couple of vendors in a inexpensive kit including new push pins....
https://www.impalassforum.com/vBullet...s-baffles.html
Bought a set and they fit well and seem to be a good match material wise.
post #3 of 3 (permalink) Old 08-17-2016, 10:53 AM
get them from "rubber the right way"
I bought the radiator & fender well kit. Plug & play install
