92 rmw heat and cold at same time... - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 03-16-2017, 09:00 AM Thread Starter
Ok so after the car warms up it blows out great heat.. Except at the feet Getting cold. Air. I would assume that there is some sort of vent sticking open allowing air from out side. But where and and how to fix is unclear
Thanks
Squeek is offline
post #2 of 5 (permalink) Old 03-16-2017, 09:55 PM
It is probably the diverter for the floor vents. You can select the floor only, and determine if heat is coming out of them. It could be the vacuum motor, or the selector valve. Check for vacuum at the valve when floor/lower is selected. If there is vacuum, it is probably the vacuum motor. You can also hook up a vacuum pump to the hoses (tan and blue), and pump the line down to see if the motor works. I do not know which one is "floor/lower", but I would suspect tan.
post #3 of 5 (permalink) Old 03-18-2017, 06:41 AM Thread Starter
Ok thank you sir. I'll see what changed after I replace the heater core that just went out yesterday
Squeek is offline
post #4 of 5 (permalink) Old 06-20-2017, 09:09 AM
Toms9C1's Avatar
Update ? My RMW doing the same thing after $900 AC fixed.
Tom
ISSCA Member #2540
95 B4U: LT4 LE Cam 1.6 RR Eibachs 17" SS Whls K&N XPypes Mech fan delete+Gary's wiring harness RM Lthr seats Imp SS Rear Disc Eaton Posi Motive 3:73's Moser Axles Stainless brake lines NEW 4L60E/Dacco 2000
94 9C1: Eaton Posi 3:08's XPypes Stainless Brake lines
95 L99 DCM: SS Clone Vogtland springs Monroe SS shocks XPypes Front end overhaul w/Alum bushings
96 RMW Woody Black / Red guts
http://badass-of-ne.forumotion.com/forum.htm
Toms9C1 is offline
post #5 of 5 (permalink) Old 06-23-2017, 12:13 PM
When you disconnect the battery, the AC reboots, and you need to run the temp up to the top and down to the bottom to calibrate the system.
