Advice please...Both fans go on and never stop.......... - Chevy Impala SS Forum
 4Likes
post #1 of 13 (permalink) Old 09-17-2017, 06:55 PM Thread Starter
After the engine gets to around 160 both fans start and won't quit unless I shut the engine off. New radiator, new coolant sensor and thermostat, new a/c radiator, compressor, drier etc. Where do I go from now? Get me going in the right direction. Thanks.
69 Black Impala Convertible
95 Impala SS Dayly driver: drilled airbox, KN filter, ported MAF, 1st base, homeplate & airpump delete, Hooker ceramic coated headers, Borla catback exhaust, Comp roller tip 1.6 rockers, LS valvesprings, Hotchkis frt & rear swaybars, UMI lca's, Konis, Vogtland springs, ZQ8's ,9c1 front calipers & pads, brake bolts mod, Goodridge stainless brake lines, 500w amp + Clarion speakers, PCM tuned by Alex.
96 9c1 sold 11-7-07
Francois is offline
post #2 of 13 (permalink) Old 09-17-2017, 10:29 PM
4x4high's Avatar
What temp t-stat did you install?
1996 DGGM Impala SS
4x4high is offline
post #3 of 13 (permalink) Old 09-18-2017, 07:28 AM Thread Starter
It's the regular one. If I'm not mistaken 195*......
96 9c1 sold 11-7-07
Francois is offline
post #4 of 13 (permalink) Old 09-18-2017, 08:46 AM
There are two temperature sensors... The one in the head (Passenger side lower on the head towards the middle if I recall properly) only feeds your Gauge. The one in the water pump feeds the PCM. Both running fans is a fail safe mode when the sensor is not connected or not working properly. Check the plug and wiring to the sensor in your water pump and insure it is correct. if not an issue then you likely have an issue with the sensor.
(I BELIEVE it is in the water pump. Or near it. Been over a decade since I last looked at my car under the hood.)
rodney is offline
post #5 of 13 (permalink) Old 09-18-2017, 08:47 AM
Get that 195 stat out of there pronto. 180 degree max,but many if not most of us prefer the 160... Usually has to be specially ordered...
post #6 of 13 (permalink) Old 09-18-2017, 10:30 AM Thread Starter
Stat is actually 180. The coolant sensor is new. It's probably the feed. I'll check out tonight. I'll let you know how it turns out. Thanks!!!!
96 9c1 sold 11-7-07
Francois is offline
post #7 of 13 (permalink) Old 09-18-2017, 10:49 AM
The Coolant Temp Sensor itself is sufficiently robust.
The wiring for the CTS connector, on the other hand, is very flimsy. You may want to seriously consider thicker gauge wiring.
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
post #8 of 13 (permalink) Old 09-18-2017, 10:12 PM
smelonas's Avatar
Just a suggestion, make sure your evap solenoid plug is plugged in. ACTUALLY.. make sure all plugs are plugged in. I know that the few times I have left plugs undone, sometimes it kicked on both fans.
These are goofy ass cars.
Mods, all the free good ones.
smelonas is offline
post #9 of 13 (permalink) Old 09-19-2017, 10:31 AM
96 Black likes the ever liven' hell outta' this.
smelonas likes this.
post #10 of 13 (permalink) Old 09-19-2017, 09:31 PM Thread Starter
We've checked all grounds and they're good. We're getting 5 volts at the sensor as the diagnostic book says we should. Unless the new sensor is junk we're heading for the PCM. We'll also check all connector including evap solenoid. Keep the info coming. Thanks for all the input!
96 9c1 sold 11-7-07
Francois is offline
