evaporator stud part number help (i did something stupid...) - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 10-22-2017, 02:03 PM Thread Starter
There are two studs (and nuts) that help secure the refrigerant (evaporator and accumulator) hoses to the flat housing of the evaporator. I couldn't see well last night and began removing them with 5mm sockets. One came out fine, but the other didn't. Under a better light, i see that they are E torx, and by my FSM, E7. Does anyone know the part number for these little jewels?
I can hit my local salvage yard tomorrow if they are expensive.
thanks-
Alchemist is offline
post #2 of 11 (permalink) Old 10-23-2017, 06:29 AM
Blue Wail's Avatar
Take the good one to ACE hardware or Lowes and match it up.
Nab
April's Sparkle Cat
383 LT1 12:1 flat top + 75 shot
11.66 @ 117 at SSHS17 Nov 11, 2017
2017 12.0 Index Champion
4140 lbs. w/ driver. front sway bar ON
Powered by 4L80E! (controlled by LT1 pcm)
Blue Wail is offline
post #3 of 11 (permalink) Old 10-23-2017, 10:17 AM Thread Starter
Nab
Thank you sir. The stud with the E7 drive on the end, I figured, is highly specialized so that Lowes wouldn't have a chance of carrying, but I will check.
post #4 of 11 (permalink) Old 10-23-2017, 01:59 PM
Blue Wail's Avatar
Yeah def won't have the E7 on the end.
I'd get a bolt with that thread, cut the head off and then simply
screw it in by hand. (or slot it for a flat screwdriver).
Nab
April's Sparkle Cat
post #5 of 11 (permalink) Old 10-23-2017, 05:20 PM
Yeah, they most likely won't have stud with a Torx on the end. So like nab mentioned, just cut a bolt head off. Or, wouldn't be surprised if Lowes or HD have a small section of studs or even some "all-thread" rod. Just be sure to get something hardened and in stainless would be "very nice". See if there is a Fastenal store near you or even something like a Lawn Mower Repair shop for the Studs.
Edit - Napa, Advance, etc may even have them in the HELP section or exhaust section.
post #6 of 11 (permalink) Old 10-23-2017, 11:03 PM
Stingroo's Avatar
Send a message via AIM to Stingroo Send a message via MSN to Stingroo
I just went through this recently. I replaced mine with bolts. New evaporator didn't have them.
Ray
__________
1992 Caprice Wagon - Gloss Black/Satin Red
The Roo Wagon
5.7L Aluminum LS1 | BTR Stage IV Truck Cam | T56 | 4.56 gears | Custom 3.5" Driveshaft w/1350 U-joints | Impala SS Rear Discs on wagon axle | Drop Spindles | Springs F Moog 5662 R Moog CC501 | 2.5 Turn Steering Box | Black U2-55 22x9.5 on all 4 corners | TBI 9C1 Gauge Cluster | Bonneville Seats w/brackets | Lots more...
Stingroo is offline
post #7 of 11 (permalink) Old 10-23-2017, 11:05 PM
Stingroo's Avatar
M8x1.25 is the thread size.
I replaced with bolts. I forget the exact length but I measured the thickness of the hose and added 5mm.
https://www.impalassforum.com/vBullet...bolt-size.html
Ray
__________
The Roo Wagon
Stingroo is offline
post #8 of 11 (permalink) Old 10-24-2017, 07:11 AM Thread Starter
Thanks for all the replies everyone. If I was a gearhead like days of old, I wouldn't have asked this.
-RT
post #9 of 11 (permalink) Old 10-24-2017, 08:17 PM
If you use stainless steel, put anti-seize on them, or they will become one with the evaporator, which is aluminum. You will probably find them at the junk yard. It will cost you far less than chasing all over town for them.
Why did you pull them in the first place? When you find a stud, it is usually to make the installation easier by aligning the parts.
Fred Kiehl is online now
post #10 of 11 (permalink) Old 10-25-2017, 04:26 PM
gbhs72's Avatar
This is late and I know it but I was looking for something and this came up. 8mm-1.25 X 35mm VOLKWAGEN INTAKE STUD Maybe you can do something with it.
Mark: Snowman-33
gbhs72 is online now
