drain recover refrigerant How To - Chevy Impala SS Forum
 2Likes
  • 2 Post By 1963SS
post #1 of 9 (permalink) Old 05-12-2018, 04:44 PM Thread Starter
boofers's Avatar
Getting ready to replace the compressor and a couple other A/C system parts. I have the FSM and Haynes manual but it is not very clear with the first step on how to drain the refrigerant. The car isn't driveable at the moment so I'm looking to DIY. I'm going to HF to get the vacuum gauges and pump but this first step is confusing me. Thanks for helping out a newbie with this!
1996 BBB, 396ci Golen LT4, Yank 3600, TransGo shift kit, 3.73s, P71 MMC driveshaft, CIA Tri-Y Gen II, X-Pipe, Dynomax UltraFlo exhaust, Hotchkis Sway bars & Springs, Bilstein Shocks, UMI extended control arms, ODBI conversion, all installed and tuned by Mike Harris
boofers is offline
post #2 of 9 (permalink) Old 05-12-2018, 05:07 PM
babywag's Avatar
@ minimum you need a recovery tank, and have to use the existing compressor to force it in.
While possible not really a diy job unless understand the process.
A vacuum pump & gauge set isnít going to do a recovery.
babywag is offline
post #3 of 9 (permalink) Old 05-12-2018, 06:50 PM
Sinister's Avatar
You have to evacuate the system with an AC recovery machine.
https://www.autozone.com/test-scan-a...ion/300780_0_0
1995 Caprice Wagon
Sinister is offline
post #4 of 9 (permalink) Old 05-12-2018, 08:14 PM Thread Starter
boofers's Avatar
So everyone just get it evacuated at a shop first?
boofers is offline
post #5 of 9 (permalink) Old 05-12-2018, 09:33 PM
1963SS's Avatar
I just killed some of the ozone layer. Mine mysteriously sprang a leak just before the compressor change. Damn the bad luck but I didn't have a recovery system. I know, somewhere in California someone is weeping, polar bears are starving on the melted polar ice, baby seals are being clubbed and it's all my fault. I'm OK with that.
TGO and gbhs72 like this.
Bill Burgette
Kentucky
ISSCA # 2216
1963SS is offline
post #6 of 9 (permalink) Old 05-12-2018, 11:38 PM
gbhs72's Avatar
HOORAH Gunny
Mark: Snowman-33
gbhs72 is offline
post #7 of 9 (permalink) Old 05-13-2018, 08:18 AM
Sinister's Avatar
No. Most just crack open a line and let it leak out. Many system failures end up with an empty system anywyas.
1995 Caprice Wagon
Sinister is offline
post #8 of 9 (permalink) Old 05-13-2018, 11:50 AM Thread Starter
boofers's Avatar
So loosening the low pressure line near the radiator would drain it then?
boofers is offline
post #9 of 9 (permalink) Old 05-13-2018, 12:04 PM
95wagon's Avatar
I remember back when the rules changed ,
Trying to be responsible at our body shop, we call the local AC place to have them come and discharge the system on a car we were working on.
Guy walks in and cracks the line and walks way !!!.
If you are trying to be responsible, you could go to an AC shop and ask for an empty freon tank.
Pump the tank down with your vacuum pump.
Hook it to the system with your gauges then let it discharge into the tank.
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
