Coolant Overflowing on my '95 Wagon - Chevy Impala SS Forum
post #1 of 15 (permalink) Old 05-28-2018, 07:42 PM Thread Starter
WaWaZat's Avatar
The upper rad hose clamp broke and the upper hose came off while driving last week. I put on a new clamp and refilled the system. On our 1st hot day this year here in Chi-Town, coolant suddenly started overflowing from the reservoir cap.
Bad cap or perhaps bad thermostat? How do I diagnose the thermostat?
Michael Szromba
'95 Roadmaster Wagon almost 300K miles
'94 Roadmaster Wagon low 100K miles
...both burgundy woodgrain!
WaWaZat is offline
post #2 of 15 (permalink) Old 05-28-2018, 08:40 PM
Just.
Don't.
It's a farkin' TS.
It's a farkin' maint./ item.
Get a farkin' new one. jk or lol or haha
Seriously, heard 4 decades ago if'n ya overheat real bad once then your TS might end up toast. Long story about my wife's Explorer -- yah so won't dare bother with details, but end story that's what I confirmed 17 years ago using it to take a stove to a colleague.
post #3 of 15 (permalink) Old 05-28-2018, 10:20 PM
It's worth asking....are you sure you properly bled the air out of the system? Trapped air can cause the engine to overheat and push out the coolant.
As for the farkin Tstat you can take it out and drop it in a pot of hot water (Tstat temp) to see if it opens. But for me, at about $10-$15, just replace it and the oring gasket.
post #4 of 15 (permalink) Old 05-29-2018, 07:23 AM
Blue Wail's Avatar
Blue Wail is offline
post #5 of 15 (permalink) Old 05-29-2018, 02:46 PM
Or,the 160 degree version for just a couple bucks more. If you don't recall when cap was replaced,get one of those too.
post #6 of 15 (permalink) Old 05-29-2018, 04:46 PM Thread Starter
WaWaZat's Avatar
Funny, I picked up a new TS from O’Reilly’s and dropped it in. Normally on my temp gauge, the needle is on the fourth line which is the very center of the gauge . Since this new TS, the needle only goes up to the second line.
What are the advantages and disadvantages of running 160 TS? Will I get less heat in the winter with the cooler one?
Michael Szromba
WaWaZat is offline
post #7 of 15 (permalink) Old 05-29-2018, 05:34 PM
Thermostat is super easy to swap if you feel you need more heat in the wintertime. Personally,I find heat to be satisfactory...
post #8 of 15 (permalink) Old 05-29-2018, 09:04 PM
From what I hear be sure to combine a 160 TS change with appropriate programming or that TS and the fan kick-ons will fight each other.
post #9 of 15 (permalink) Old 05-29-2018, 09:24 PM
Fans will operate as before,but will operate less... If install a hotter stat with reprogrammed fans is where issues with fan operation occurs.
post #10 of 15 (permalink) Old 05-31-2018, 09:12 AM
Depending on your cooling system the only real problem is you may never get into full "run" mode where your reading the O2 sensors and it dumps more fuel into the system. Which requires a reprogramming to knock it out of Open loop. (Open/Closed loop are where the O2 sensors are ignored or looked at for fuel management. The idea is to get your engine up to temp faster so the pollution controls work quicker. But I never remember if Open or Closed loop is the phase where it ignores the O2 sensors and dumps fuel. Thought Closed loop is normal operation and Open loop is startup but I could be wrong.)
rodney is offline
