LS Swap Radiator Hose: Griffin Radiator - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 08-09-2018, 08:19 PM Thread Starter
Hello all,
I have swapped in a 5.3 and I have a Griffin LS swap radiator, which means the inlet and outlet for the radiator are both on the passenger side. What radiator hoses are you guys using (especially on the bottom) for this setup?
Thanks,
Vetteman61 is offline
post #2 of 2 (permalink) Old 08-10-2018, 05:46 PM
95wagon's Avatar
Many variables.
Car water pumps , the the outlet position changed dramatically around 08-09 ( own two 09 G8s and they are completely different due to production dates)
Anyway, my car.
08 and older water pump
Dual pass rad, both inlet and outlet passenger side. difference is my inlet and out let is not straight
Upper rad hose is stock impala flipped over.
Lower is a Jeep JK v6 upper .
I use a straight thermostat housing from CBM
https://store.custombuiltmotors.com/...r-necks-1.html
http://carphotos.cardomain.com/ride_...4303_large.jpg
http://carphotos.cardomain.com/ride_...4299_large.jpg
Because of my rad differences, my hose set up may not work for you
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
