Cold Case Aluminum Radiator? - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 08-17-2018, 09:24 AM Thread Starter
These days there are few options for radiators. I found the Cold Case CHI579A, which is all aluminum, has 4 cooler connections, and is "oversized 2 rows". Manufacture location is not disclosed, I suspect the orient.
https://www.coldcaseradiators.com/ch...ance-radiator/
It retails for $369, but I have a price of $325 plus $35 shipping to Georgia from ss396.com and gtog8ta.com. Has anyone on here used this radiator?
nickss96 is offline
post #2 of 11 (permalink) Old 08-17-2018, 09:26 PM
I sure haven't. $369? No thanks.
Are you having trouble finding an all-aluminum Silla radiator?
https://www.impalassforum.com/vBulle...-radiator.html
https://www.impalassforum.com/vBulle...impala-ss.html
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
post #3 of 11 (permalink) Old 08-18-2018, 05:15 AM
juniorwatson's Avatar
Well this isn't an all aluminum radiator,, but this is the traditional with the plastic side tanks. I can't believe the price of $86.88
https://www.stockwiseauto.com/auto-p...&Model=Caprice
juniorwatson is offline
post #4 of 11 (permalink) Old 08-18-2018, 11:50 AM Thread Starter
If I were into plastic aftermarket radiators, it would be very difficult to beat $87.
That same outfit, however, also has two all aluminum Silla radiators
the 2395AA (no external motor oil cooler) for $160
and
the 2396AA (with external motor oil cooler) for $176.
The Silla 2396AA is not available. The only aluminum ones I have found are the Cold Case and a Liland Global on Amazon for $223. I've put Spectra in my other cars, but the plastic always cracks and leaks after a while.
nickss96 is offline
post #5 of 11 (permalink) Old 08-19-2018, 06:16 AM
Okay, just for clarity, what's your budget, what are you willing to spend?
That'll help for further recommendations.
post #6 of 11 (permalink) Old 08-19-2018, 07:52 AM Thread Starter
I'm willing to pay more for better quality. I hate rework. I would be happy with the $87 plastic one, but I have tried them in the past on other cars and wound up replacing them shortly after install. That is why I wanted to find out about the Cold Case. I hate to be the guinea pig, and $360 is about the most I'm willing to spend, but if it lasts 22 years like the OEM I would be happy.
nickss96 is offline
post #7 of 11 (permalink) Old 08-19-2018, 08:32 PM
Jegs has the Cold-Case radiator for $325.
https://www.jegs.com/i/Cold-Case-Rad...I579A/10002/-1
Listed as Made in USA.
Let me know if you get one as I probably need a new radiator soon to cool the the new engine in this Texas Heat.
Michael
2012 Best of ISSCA; 2013 ISSCA Nats FTD Autocross and Road Racing
1995 BBB: - ERE383 #74 516 FWHP/526 FWTQ
1984 Monte Carlo SS 12.8 @ 104
2005 GTO M6 357.7 RWHP and 358.8 RWTQ PCMFORLESS
madamorr is offline
post #8 of 11 (permalink) Old 08-20-2018, 03:34 PM
Michael
For all their hype, no where does Cold Case say Made in the USA:
https://www.coldcaseradiators.com/coldcasecomparison
That said - looks like a quality item. Their applications for older cars is impressive and much needed.
grandpas wagon
grandpas wagon is offline
post #9 of 11 (permalink) Old 08-20-2018, 03:50 PM
IDK anything about or have heard of Cold Case. The Jegs listing shows a "made in America" logo for the product....but as noted in post above Cold Case website is void of that note....something I would assume would be front & center if they were made in USA
Given its price point it likely is not. Doesn't mean it is a bad radiator but again I have no knowledge of their product
I have a Four Seasons (FSR) and it is USA made, Michigan. It is more than $350 though...
post #10 of 11 (permalink) Old 08-20-2018, 03:59 PM Thread Starter
Madamorr, that is a good find at Jeg's because of the free shipping. I read on a forum somewhere that they are made in Taiwan. I ordered the Liland Global for $182 from carparts.com. If it fails the receipt inspection, I plan to order the Cold Case.
nickss96 is offline
