Radiator upgrade question - Chevy Impala SS Forum
 1Likes
post #1 of 16 (permalink) Old 12-05-2018, 04:29 PM Thread Starter
GreenWitINv's Avatar
Looking to upgrade my radiator. I don’t want to pay Be Cool prices. Anyone with experience with the KKS brand radiator?
GreenWitINv is offline
post #2 of 16 (permalink) Old 12-05-2018, 04:37 PM
Why are you upgrading your radiator? 99% of the time, if you're running hot - it isn't the radiator's fault
fbi9c1 likes this.
atlantadan is offline
post #3 of 16 (permalink) Old 12-05-2018, 05:20 PM Thread Starter
Car isn’t running hot (not even after a beating). I plugged the TB coolant passages, i have a 160 degree thermostat and Electric water pump a WHILE ago. I figured i would go ahead and replace/upgrade the radiator and throw in some ice...
post #4 of 16 (permalink) Old 12-05-2018, 06:34 PM
gbhs72's Avatar
There was mention of this about a month ago. https://www.rockauto.com/en/moreinfo...049701&jsn=455
And this one, https://www.rockauto.com/en/moreinfo...049701&jsn=455 Both are aluminum. Don't forget to add your discount.
Mark: Snowman-33
gbhs72 is offline
post #5 of 16 (permalink) Old 12-06-2018, 05:10 AM
gbhs72's Avatar
Arrow Update
I got to checking more. Look at this for some more info. https://www.impalassforum.com/vBulle...or-1517aa.html Hopefully more good replacement items will come our way for our cars.
Mark: Snowman-33
gbhs72 is offline
post #6 of 16 (permalink) Old 12-06-2018, 05:43 AM Thread Starter
Any consensus on 1-row vs 3-row radiators? I just ordered the KKS 3-row all aluminum radiator for less than $250 with lifetime warranty. Supposed to be a direct replacement.
KKS 3 ROW STAMP TANK ALL ALUMINUM RADIATOR 94-96 CHEVY Caprice/Impala 4.3 5.7L
post #7 of 16 (permalink) Old 12-06-2018, 06:48 AM
juniorwatson's Avatar
I don't recall who the supplier was at the moment, but I know a thread within the last 6 months or so listed the all-aluminum model a member had installed.
m
THAT would certainly be what I'd be looking at in the case I do need a replacement any time soon
(NO deer, you stay away from my car!!)
juniorwatson is offline
post #8 of 16 (permalink) Old 12-07-2018, 08:00 PM
m
That'd be me. It's the Liland 1517AA in a 96 Impala. It has a few hundred miles on it and it has been good so far. BTW, I got mine from carparts.com for a little cheaper with a code. I can tell you that Liland was quick to answer when I sent them a question via Messenger during the install.
nickss96 is offline
post #9 of 16 (permalink) Old 12-07-2018, 08:04 PM
Originally Posted by GreenWitINv View Post
Car isnít running hot (not even after a beating). I plugged the TB coolant passages, i have a 160 degree thermostat and Electric water pump a WHILE ago. I figured i would go ahead and replace/upgrade the radiator and throw in some ice...
You also have the programming for the thermostat? I put the 160 stat in and had the pcm programmed for it and Tri-Y headers. Now my wife freezes in the car.
nickss96 is offline
post #10 of 16 (permalink) Old 12-07-2018, 08:34 PM
Thanks for following up with this thread, just for my own selfish reasons. I'm going to print out the thread to store in my 3-ring binder with other 'keeper' threads I have saved & printed.
Surprising, as I did a right-click search for it, and Amazon listed as out of stock. Well a few scrolls and clicks show RockAuto to have it these days.
