flare plug for radiator - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 12-13-2018, 10:26 AM Thread Starter
I am deleting my oil cooler lines, so I need to plug my aluminum radaitor. What type and what size plug will I need to get this done? I believe it will be an inverted flare plug , but what size and what thread count. Thanks
BH tuning, Transgo shift kit, Eaton posi W/ 3:73 gears, EDGE 9.5" 3000 stall , BMR rear lower control arms. BMR front and rear sway bars Hotchkis springs, CIA trans crossmember; 1.6 Pro magmuim RR; CIA budget headers w/ high flow cats; 2 1/2" cat back with X pipe; chrome dual cone CAI, 52mm throttle body, 30lb SVO injectors, Wilwood brake calipers, Power Stop drilled and slotted brake rotors, Bilstein shocks. Gary's 2 relay headlight harness. Gary's battery relocation harness
my95ss is offline
post #2 of 11 (permalink) Old 12-13-2018, 11:55 AM
gbhs72's Avatar
Check this out. Post #5: https://www.impalassforum.com/vBulle...il-cooler.html
Mark: Snowman-33
gbhs72 is offline
post #3 of 11 (permalink) Old 12-13-2018, 01:57 PM
Blue Wail's Avatar
Its 3/8" inverted flare male plug.
Nab
Blue Wail is offline
post #4 of 11 (permalink) Old 12-13-2018, 02:02 PM Thread Starter
Thanks guys! I see that Summit sells them.
my95ss is offline
post #5 of 11 (permalink) Old 12-13-2018, 04:59 PM
babywag's Avatar
Lowe's locally had some, any place that has decent hardware selection should have plugs.
Sure wouldn't pay an inflated price and shipping for them.
babywag is offline
post #6 of 11 (permalink) Old 12-13-2018, 05:51 PM Thread Starter
Wink
This I know all to well. But I am fortune enough that Summit is 5 miles from my house and they only want $2 each for the plugs
my95ss is offline
post #7 of 11 (permalink) Old 12-13-2018, 06:00 PM
gbhs72's Avatar
Well that just sucks.....
Mark: Snowman-33
gbhs72 is offline
post #8 of 11 (permalink) Old 12-14-2018, 06:15 AM
I'm not a 100% sure on this but think the engine oil cooler lines going into the rad are larger than the Trans cooler lines which are 3/8" inverted flare. I only say this cause the oil cooler lines are 1/2" and the Trans cooler lines are 3/8".
Don't really "need" to plug those as it really won't hurt to just leave the ports open. I run the ext 9C1 cooler on my car which bypasses the in-rad cooler. I just used some rubber plugs to block off these ports so dirt/bugs don't get in there. But if you are concerned with looks, a nice plug would certainly look better.
post #9 of 11 (permalink) Old 12-15-2018, 02:13 PM
Just checked a spare Radiator I have and both the Engine Oil and Trans Fluid Cooler fittings are the SAME ---- 3/8" inverted flare.
Not sure why they step down the 1/2" oil cooler line down to 3/8" oil cooler other than convenience/cost. May not matter much but maybe another reason to run the Ext. Oil Cooler since it's 1/2" the entire way.
post #10 of 11 (permalink) Old 12-15-2018, 03:38 PM Thread Starter
Cool
Thanks 4DoorSS you are always a great source of info!
my95ss is offline
