Noise from a/c blower....? Need your help - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 01-03-2019, 12:29 PM Thread Starter
96ChameleonSS's Avatar
Question Noise from a/c blower....? Need your help
Hi all. Just wanted to ask how to access the A/C blower in the Fleetwood? There is this noise coming from the glove box area when I turn the a/c on. Sounds as if the fan is hitting something (say a leaf, for example. Maybe hitting a piece of electrical tape ). It does not happen all the time. However, when it does happen this is what I notice: let's say the noise is there while driving or when I am at a full stop. If I take off quickly (accelerate) then it goes away. It also goes away when I make a turn. Is this related to the blower? Is it accessible after removing the glovebox in a Fleetwood? Having the A/C fixed now with all new components and would like to take care of this ASAP. Your feedback will be appreciated
Thanks
96 DCM Impala SS
96 Cadillac Fleetwood, Triple Black w/ Sunroof
96ChameleonSS is offline
post #2 of 3 (permalink) Old 01-03-2019, 05:31 PM
You won't need but the last pic here for reference to the orientation of 3 little screws you're hunting for, to drop the housing with motor and blower.
https://www.impalassforum.com/vBulle...wer-stays.html
To get at them you'll remove the kick panel, lower dash conceal and maybe the sill plate. All easy screws. The housing screws are gonna be 5.5, 6 or 7mm head, and you'll find as I have anything from a square block of foam, leaves, twigs, dead mice (lucky if no babies or too much poop). Lysol the whole thing and give motor 2 drops of 3-in-1. There's a little foam donut around the motor cooling tube - usually rotted or gone. Make up a new one to optimize volume/velocity.
post #3 of 3 (permalink) Old 01-04-2019, 11:28 AM Thread Starter
Thanks
Thanks 96 Black, I will tackle that this weekend
96 DCM Impala SS
