No Blow From AC/Heat - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 01-14-2019, 05:58 PM Thread Starter
WaWaZat's Avatar
My climate control in my ‘95 wagon lights up.... fan speed lights even operate.... but nothing is blowing. Short on time so brought it to my local mechanic. They tell me it’s the blower motor and blower motor resistor. This is my 300k mile winter car, but may be getting rid of it in a year or so, so don’t want to rack up a bill. They tell me the motor is $55 and resistor $200.... plus $100 install.
Any recommendations on where to at least save money on the resistor and pick one up for much less?
Michael Szromba
'95 Roadmaster Wagon almost 300K miles
'94 Roadmaster Wagon low 100K miles
...both burgundy woodgrain!
WaWaZat is offline
post #2 of 4 (permalink) Old 01-14-2019, 06:15 PM
jayoldschool's Avatar
Buy a used resistor from one of us. Bench test your fan, replace with used if needed. Replace them yourself. It will take about 20 min.
jayoldschool is offline
post #3 of 4 (permalink) Old 01-14-2019, 06:46 PM
Your symptoms do not sound exactly like I had, but enough same components at play that you might pick pieces/hints from here:
https://www.impalassforum.com/vBulle...wer-stays.html
If you have true climate control then it's called a module. A used one is a viable gambit, but did not pan out for me. I found cheaper equally performing alternates to "that genuine GM feeling".
EDIT: As referred below, parts procured on this forum are historically more reliable than internet, though I (luckily) got extra-rapid refund for my (unfortunately dead) ebay purchase.
Last edited by 96 Black; 01-14-2019 at 09:33 PM. Reason: possesive case v. contraction don't cha no- Plus editorial on forum sellers
post #4 of 4 (permalink) Old 01-14-2019, 07:18 PM
Check the fan by removing it, and putting battery voltage across the leads (it has a lot of torque, so be careful), and if the fan works, replace the module (you can get one here for about $50). If the fan does not run, replace the fan (also available here for about $50). I have both parts.
