Hose clamps - Chevy Impala SS Forum
 3Likes
post #1 of 28 (permalink) Old 03-25-2019, 12:55 PM Thread Starter
JZ9C1LT1's Avatar
Hose clamps
Are there any good hose clamps out there? Put some brand new ones on from Autozone and they keep backing off. Total garbage anymore. I talked to a mechanic recently and he they sometimes double up on the clamps because of this problem.
I'm talking about radiator hose clamps.
Ftbird0909 likes this.
96 9C1 LT1 with all the bolt on crap (Gone 1/08 to 9C1 heaven aka junkyard!)
95 9C1 LT1 New toy as of 6/09 (this one is now heading same direction as the 96)
95 9C1 LT1 The new black mariah! SOLD
95 9C1 LT1 Will be my whenever I get it done project!
94 Caprice
04 GTO SOLD
Originally Posted by BewbZowt(+ Y +)
Here's how it works: If I can see them, they are real.
JZ9C1LT1 is offline
post #2 of 28 (permalink) Old 03-25-2019, 01:47 PM
Z09B4U's Avatar
I have not been making/maintaining hoses for the last five years but before that I made hundreds with Tridon hose clamps without having that problem. Most were hot water or air at 50-100psi but most were not subjected to extreme vibration. The better choice is the "lined" stainless steel clamps. A lined hc is the only choice for silicone hoses as the slots damage the hose.
For radiator hoses I have been replacing hose clamps with factory spring clamps as they are much wider. This is what they are trying to copy when:
If the spring clam is undamaged it seems to hold without leaks or adjustment. They have been trouble free on my truck for over 25 years and 22+ on some daily drivers.(Tougher than the radiator)
Z09B4U
Z09B4U is offline
post #3 of 28 (permalink) Old 03-25-2019, 01:50 PM
Blue Wail's Avatar
Agree with Z09. Factory spring clamps are the best because they apply equal pressure
all the way around the hose whereas a screw clamp applies most pressure on the screw side
of the clamp. Screw type clamps also tend to dig into and tear up the hose.
Nab
Blue Wail is offline
post #4 of 28 (permalink) Old 03-25-2019, 03:24 PM
babywag's Avatar
Nab
Agreed! worm gear clamps suck and even worse nowadays with all cheapnese ones that are really bad.
When I replaced all the hoses on mine after buying it I put spring clamps back on every connection. Had to hit the boneyard for some donors but not a single leak.
Have even removed/reinstalled a few for opti work and still no leaks/problems.
I never use the worm clamps on anything unless in a pinch.
babywag is offline
post #5 of 28 (permalink) Old 03-25-2019, 03:36 PM
They've got heat shrink hose clamps out for a while now - Something else to consider
https://www.gates.com/us/en/fluid-po...lamp/p/p100748
I use stainless steel T-Bolt clamps and have never had an issue with them. Be sure to get the 100% stainless ones, not the ones with steel nut/bolt that rust together.
I've found that Silicone Intakes have full stainless ones for reasonable cost
T Bolt Clamp
gbhs72 likes this.
Fix Until Broke is offline
post #6 of 28 (permalink) Old 03-25-2019, 04:50 PM
gbhs72's Avatar
I'm going to try what Fix has shown here.^^^^^^^^^ The Gates clamps. There have been past posts about them and they seem to be a good deal. They just have a cleaner look about them too.
Mark: Snowman-33
gbhs72 is offline
post #7 of 28 (permalink) Old 03-25-2019, 05:55 PM
Can't say I've heard of worm gear clamps loosening up on their own before but there are some cheap clamps out there. When going with Green hoses, I spent some money on quality Stainless Lined Clamps I got from MSC catalog. Little pricey compared to the parts store crap but never an issue with them. You can tighten worm gear type clamps too much which can cause the clamp to come apart and they don't clamp good after that.
post #8 of 28 (permalink) Old 03-27-2019, 09:27 PM Thread Starter
JZ9C1LT1's Avatar
Thanks for the replies! These are just standard hoses not the green hoses. Going to check the boneyards this weekend and if nothing, going to buy the ss t-clamps.
94 Caprice
04 GTO SOLD
JZ9C1LT1 is offline
post #9 of 28 (permalink) Old 03-27-2019, 11:31 PM
spring type clamps
When I first started working on cars I hated spring clamps, now I'm liking them, and was thinking about getting an assortment box from Amazon. Anyone have any experience with any particular brand? And am trying to figure out sizing, like, what size works best for 5/8 heater hose?
VM
VManganese is offline
post #10 of 28 (permalink) Old 03-28-2019, 04:45 PM
schlicky13's Avatar
It's been my experience for awhile that auto part store clamps are cheap chinesium junk, even if they're stainless only the band is and the screw mechanism is not and will still rust. If you want good stainless worm gear clamps, just hit your local hardware store (lowes, menards, etc.) and meander on back to the plumbing section, you should have no problem finding any size you could want in 100% stainless and they come in convenient bags of 10 or 20 or something like that. I keep a medium plastic tote full of them on hand so I never have to run and get one if I need it. So far I've had zero issues with them.
If you want to stick with the spring clamps, get a decent pair of spring clamp pliers, they're worth their weight in gold. There are two versions, I recommend the extended cable version, you can get that into darn near any place they stuck them and release them with ease. I found a pair that are made in France, so hooray for not being chinesium junk. On a side note, anyone know if those gates compression things are single use or can they be reused? I've seen them before but I thought they were single use only and for as often as I'm taking stuff apart to fix other things, I'd probably go through a ton of them.
https://www.amazon.com/Mayhew-28655-.../dp/B0002UNPHI
This is this frenchie set that I bought, but I've literally never used the standard pliers looking one. Even if the clamp is easily accessible, inevitably it'll be clocked such that you can't get on them with that one anyways. The cable one works beautifully every time, so if that's available by itself I'd recommend it. I think it was also branded and sold under the Craftsman name at one time, because I came across some on ebay that were craftsman, looked identical and said made in France.
Something witty.
schlicky13 is offline
Similar Threads
hose clamps for 9C1 hoses turbochris Heating/Cooling/HVAC 13 02-20-2012 09:07 PM
RED Samco Silicone Hose kit w/summit hose clamps 95BLKSS Parts for sale/wanted 16 01-24-2012 07:39 AM
SSFlex hose and Magna clamps 96BBB Exterior 4 08-28-2004 09:06 AM
green hose clamps my94SS Engine Performance 0 06-07-2002 01:16 PM
don't forget the hose clamps... kamchief Engine Problems/Maintenance 1 12-28-2001 10:11 PM
