Time has come to fix CEL previously diagnosed as Fan Fault - Page 2 - Chevy Impala SS Forum
 2Likes
post #11 of 20 (permalink) Old 04-26-2019, 11:12 AM
Originally Posted by ace72ace View Post
Yep, I get it, but I'm at the point where I just need it fixed - no matter how simple it is to check X, Y, Z. I was assured their 'wiring guy' is the best and knows his bleep. So we'll see how it goes.
…..well you asked the ? on a forum...and I replied with what is a fairly common cause of your "both fans on at cold start up". The check is simple, if you have a DVM. Or you could just buy another ECT sensor and put it in
the "wiring guy" may be the best guy on the planet to do wire repair but will need to know before doing anything to check resistance of the sensor and if he checks it would need to know the correct ohm per temp so if he doesn't I would encourage you to provide the information (link I posted)
again you will spend more time, let alone $, taking it to this guy to check the sensor first...but I digress.
the ohm test would rule in/out the sensor.
connectors that are removed for servicing the car. like replacing a WP for example, can get the wires in/to them messed up if one pulls on the wire while trying to remove a connector or the wire at the connector just finally succumbed to heat/use. Typically a close visual inspection or using the continuity function of a DVM to probe terminal and a few inches above the connector to reveal if continuity is good in the wiring/terminal at the connector will show if wiring is good
Given the location of the ECT sensor….this is a extremely easy one to check
grandpas wagon likes this.
BALLSS is online now
post #12 of 20 (permalink) Old 04-26-2019, 11:20 AM Thread Starter
Much appreciated, however I don't have a DVM. I will pass along the info provided.
ace72ace is offline
post #13 of 20 (permalink) Old 04-26-2019, 01:24 PM
91ss's Avatar
I couldn't see any evidence of bad caulk on the rear quarters, just a little crack in it in the top of the 2nd pic. Will look at this area more closely and check for moisture underneath that area.
The seam is up at the roof. Not where you're showing in the pictures. ANY cracks up there will have water running along the underside and drip where you show in the pictures. But it's coming from the top.
91ss is offline
post #14 of 20 (permalink) Old 04-26-2019, 01:30 PM Thread Starter
Ok, I will document this in the proper sub forum as this side topic doesn't belong here. Do you recall any images posted that show the cracked caulk?
[Edit found existing thread in Exterior sub forum]
ace72ace is offline
post #15 of 20 (permalink) Old 08-15-2019, 09:04 AM Thread Starter
Had to update this thread as I got my 95 SS back from the shop, and they couldn't figure out how to get the fans to stop running in failsafe mode all the time. The mechanic did his best to test all the wiring and connectors for proper voltage and visual inspection for loose/corroded/stripped wires as well. They had a look at the forum post for troubleshooting fans (the one that includes the ECT Temp vs Resistance Values chart). Given the Opti is original and car now has 130k on it, it's a good time to replace it. The CEL is throwing codes for a faulty Opti, so I'm having the ebay rebuild service done and replacing the water pump, and required seals myselfl. I was expecting a huge bill for all the work that was done while they had the car, which included replacing the ECU (which I provided), troubleshooting the fan issue, state inspection, and replacing faulty windshield washer fluid motor was just 242$. Car runs much better now, as before it would sometimes stumble as if it wasn't getting fuel. If we still have CEL after replacing the Opti and the fans are on, I can bring it back and they will check the code and see if they can chase it down. Luckily in NH you can still pass inspection with a CEL for a vehicle that is so old.
At this point I'm wondering should I just spend 12$ and replace the temp sensor in the water pump? This amazon link uses the exact same picture as the one listed on Rock Auto;
https://www.amazon.com/Delphi-TS1007...dp/B000CGM9O2/
https://www.rockauto.com/en/moreinfo...9699&jsn=11746
I know that the die hards on this forum always recommend performing a proper diagnosis and systematic troubleshooting method to test parts, but when it's a cheap and simple replacement I'm not averse to replace something while I've got the tools out and and am working on it.
ace72ace is offline
post #16 of 20 (permalink) Old 08-15-2019, 09:16 AM
At this point I'm wondering should I just spend 12$ and replace the temp sensor in the water pump? .
did you ohm the sensor and use the chart that notes what temp=ohm it should be?
I doubt the opti has anything to do with the fans staying on
If sensor checks out using your meter I would back probe the wires going to the sensor all the way to PCM.
You confirm the fan relays are not frozen "on"?? (and also read the contacts they plug into are not melted and shorted...which was a TSB)
Spending $12 on a new sensor is fine if you want. You should be able to "quickly" install it after unscrewing the old one without much coolant loss so you would not need to bleed cooling system
post #17 of 20 (permalink) Old 08-15-2019, 09:30 AM Thread Starter
Agreed, the Opti shouldn't have anything to do with the fan issue, but just clearing codes systematically. I have mentioned before that the previous owner appears to have gone off roading and the passenger side fan was stuck as the lower support was jammed up into the fan preventing it from turning and it burned out. I replaced it, but since then they have always been always on. I'll see if I can get my hands on a DVM to do some testing.
ace72ace is offline
post #18 of 20 (permalink) Old 08-15-2019, 09:46 AM
At this point I'm wondering should I just spend $12 and replace the temp sensor in the water pump?
Yes. Also do a 'jiggle & wiggle test'. I once had a problem where my engine would stumble every time I hit a bump or made a right turn without stepping on the gas. Turns out the wire would behave, unless I grabbed it and moved it an inch away from its resting position.
1g1bl82p7rr127841 … Rust In Pieces, Rest In Peace …
They are NOT Lying to You
You are NOT Lying to Yourself
… Alone aka The Last Psychiatrist
Marky Dissod is offline
post #19 of 20 (permalink) Old 08-15-2019, 10:33 AM
Z09B4U's Avatar
BALLSS
"frozen on" relays would make the fans run all the time key on or off. The fan relay feed is hot at all times.. Melted contacts in the box are more likely to prevent the fans from starting. Give the shop some credit, most will start by trying a new relay. It would do the OP no harm to try a borrowed or new relay but it probably will not help. If you can hear or feel the relays click and the fan comes on you do not have to look at the relay and fan part of the circuit.
ace72ace Without OBDI live data you are wasting resources. If the PCM is showing the engine's temperature correctly then check if the PCM is turning on the fans. The OP will have to focus on PCM output to the fans and the possibility that the original owner has bypassed the PCM or the remote possibility the PCM is damaged. IE: PCM shows fans off but the outputs are grounded and turn on the relays.It is unlikely that two PCMs are bad.
The reason throwing parts at it without live OBDI data is bad is the problem could be related to a bad pressure sensor on the freon line, A/C commanded on or some other cause that makes the PCM turn on the fans. Engine coolant temperatures are NOT the only thing that can force the fans on.
ace72ace if you want to get the most out of your repair dollar find a shop with OBDI live data and a reputation for being able to do diagnostics. Get a FSM it may help.
Z09B4U
Z09B4U is offline
post #20 of 20 (permalink) Old 08-15-2019, 10:52 AM Thread Starter
Thanks, that's the hardest part finding a shop with ODB1. I have the FSM if it needs to be referenced.
Interesting to note, my AC isn't holding a charge. It wasn't blowing cold when I first got it, and I suspect the seals have dried out. I recharged it last year but now it's not cold at all, just another thing to fix... sigh.
ace72ace is offline
Similar Threads
GM closing Janesville even earlier than previously thought VIN Guy's Alter Ego Misc. 6 10-13-2008 07:17 PM
New SRS air bags into previously wrecked? 96greengrey Concerns 5 09-13-2005 01:44 PM
CEL Fault code "026 CCP Elec Fault" liljiggaboy Engine Problems/Maintenance 1 08-26-2005 12:02 PM
CEL and radiator fan come on periodically, is that my AIR pumping going out? tlynch Engine Problems/Maintenance 14 05-30-2004 02:06 PM
Need a CEL code diagnosed SSweet1 PCM Programming/Engine Management 1 08-31-2002 05:21 PM
