Different fans for HD radiator? - Chevy Impala SS Forum
post #1 of 28 (permalink) Old 05-15-2019, 10:07 AM Thread Starter
SSandman's Avatar
I purchased an FSR LS1 conversion radiator for my 96 SS build but I ran into a problem when I went to install the fans. I took the fans off my old radiator and my first issue was that the clips of the top and bottom did not fit over the flange of the new radiator as the flange was too wide. Next, when trying to mount the fans, I saw that the holes in the fan mounting legs were larger than the posts welded to the radiator so they end up sitting over the posts instead of on top of the post. This caused the fans to drop too low and one ended up touching the tank.
I called up FSR and they told me that they built their radiators to replace the "HD" 1 3/8ths radiator and that I must have had the 1" standard radiator. That would make sense as to why the mounting clips wouldn't sit over the flange. I didn't even know there was an "HD" radiator option for the SS though. Do the cooling fans mount differently on that radiator?
I could make this work, but I'm thinking if I could just find the "HD" fans and mounting clips then supposedly they should bolt right up.
FSR offered to take the radiator back and modify it to work with my fans, i'd just rather skip the hassle of shipping it.
SSandman is offline
post #2 of 28 (permalink) Old 05-15-2019, 11:28 AM
Z09B4U's Avatar
I guess we still are learning about these cars. I was going to say BS about the clip differences. But for some reason there are different radiator clips for 96 vs 94/95,
I will call BS on the fan motor frame mounts. There is only one right fan mount listed for 94/95/96. For the left there are four. The listings are all for 94 to 96 but that does not make sense. One goes with the clutch fan, one would be for the 94 only large electric motor, what differences are between the last two are in the order codes. They all use the year appropriate mount clips.
The radiators seem to all be the same. The core is listed as NS so there is no way to verify width, BUT if there were different widths there would have to be two different clips for each year. The end tanks are different depending on transmission and oil cooler packages.
Check a online supplier to figure out if there was a width difference between 94/95 and 96 rads. The afermarket stock rads would have to match the clips or there would be many complaints.
Z09B4U
Z09B4U is offline
post #3 of 28 (permalink) Old 05-15-2019, 11:51 AM
There's a rather entailing thread (or two) on the various fan combos, some info may spill over pertaining to the radiator. I've had to attend to fans on both my cars, and can only mention a couple things crossing over to what you need. Aftermarket larts listings are misleading and in a few cases downright wrong. Both my cars do NOT have the 'HD cooling', which I believe is reserved for just tow package FWs and RMs (V4P). Both cars DO however have heavier duty fan setups than some reported base Caprices in that the PS fan is primary and smaller (100amp?) and the DS is secondary and larger (130amp?). Not interchangeable side-to-side as the motor housings are not reverable mirror image and measurably different fan diameters that are not practical to mod the center fan attachments. Putting a bigger DS fan in the PS is not feasible either for the same reason. There are some guys swear they have the smaller fans stock on both sides (L99?, Caprices without tranny coolers ? IDK)
A guy might think if no mech. fans then no 'HD cooling' and/or no thick radiator (even if there is one). Maybe look up rad apps for a FW and SS and see how similar, and then look up a Cady/Buick V4P to see a difference. I can tell you some part house listings refer to the 130amp fan as 'HD' but improper GM terminology.
HTH, likely not.
post #4 of 28 (permalink) Old 05-15-2019, 01:40 PM
Maybe the "LS" core FSR uses is different than the one they use for 96 LT1 B-body
FWIW I have a FSR in my LT1 with no coolers and my "stock" 96 fans were plug & play
post #5 of 28 (permalink) Old 05-16-2019, 11:25 AM
Z09B4U's Avatar
Re 96 Black: I think he means Watts when he wrote Amps. Fans were 100,150, and 240 Watts.
BALLSS Thanks for the pictures. Thumnails may be smaller but they are on the forum and may outlast 3rd party picture hosts.
BALLSS and 96Black, you both say your 96 is stock but you show the V03 cooling fans(one 240W). Would you both check what cooling system your SPI sticker shows? The rumor is the 240W was 94 only.
I have a quote(Scott?) that was posted somewhere.
Their were 3 fan motors used in the 94-96 cars. 100 watt,150 watt and 240 watt. The 100 and 150 used the same mount,the 150 was just a little deeper.100 and 150= completely interchangeable and put on MANY cars. The 240 watt is a different story. It uses a different mount and its only available for the driver side. The 240 watt cools VERY well, however continued use WILL melt the weak stock relays and any sockets their put in! The startup current is just to much. It was mostly used as the secondary to the mechanical on towing versions. It does have a few other applications as well! The fan itself is interchangeable with all 3. The V92 tow pack always includes V08 cooling, which always includes the mech fan [which incurs a 10 peak horse penalty].
Does it also include an extra trans cooler?Technically, no. All 94-96 B-cars have an integral transmission cooler close-coupled to the radiator.
All LT1 B- & D- cars also have an additional external transmission oil cooler.Does RPO V08 also include a heavy duty radiator as well?Couldn't tell you. These days, the only radiator variants I can find are:
civilian radiator with integral motor oil & transmission oil coolers
9C1 radiator with integral transmission oil cooler only, no oil cooler
(On this, I could be misinformed.)Is there a difference between base cooling and extra-capacity cooling?The base cooling option was a 150W primary fan, and a 100W 2ndary fan.
The V03 cooling option upgraded the 2ndary fan to 240W.
The V08 cooling option that came with the V92 tow pack upgraded the primary fan from a 150W elec fan to a 7,457W mechanical fan, and kept the 240W 2ndary.There are two optional cooling system upgrades for LT1 B/D-cars, called V03 (Extra Capacity Cooling), and V08 (Heavy Duty Cooling). Performance models such as the WX3 (Impala SS) and 9C1 (Police) cars automatically get the upgraded V03 (Extra Capacity Cooling) system. V03 includes a larger radiator, an increased capacity A/C condenser, and an upgraded secondary electric fan. V03 is also optional on most B/D-car models.
Note that the '94 V03 (Extra Capacity Cooling) option uses a 150-watt primary (RH) fan, and an upgraded 240-watt secondary (LH) fan. In '95-'96 the V03 package was revised and no longer included an upgraded 240-watt secondary fan. Instead the standard 100-watt secondary fan was used, which is the same as the base cooling system.
PM538 for the driver side and PM540 passenger side on SS cooling package. The driver's side fan on my car has part number 22137068 and the PM9040 is the direct replacement.( '95 Caprice wagon)
The primary fan is the one on the passenger side. It comes on when the A/C is on or if the A/C is off and the temp gets to 228 degrees. The other one is the secondary fan and it comes on when the temp gets to 232 degrees.
ACDELCO Part # 158498 {#22137318} MOTOR KIT,ENG CLG FAN RIGHT HAND; w/o HVY DUTY CLG(V08)
ACDELCO Part # 158490 {#22136414} MOTOR KIT,ENG CLG FAN LEFT HAND; w/o EXTRA CAPACITY CLG(V03) or HVY DUTY CLG(V08)
ACDELCO Part # 158429 {#88890735} MOTOR KIT,ENG CLG FAN LEFT HAND; w/ENG OIL CLG(KC4) or EXTRA CAPACITY CLG(V03) or HVY DUTY CLG(V08); IDENT ASM# 22137220
The CORRECT GM # is 88890735 List $140.00 Shop $ 100.80
Same part ACDelco 15-8429 GM PART # 22137318
PACK QTY: 1
List Price: $132.28
Price: $68.12
DESCRIPTION: MOTOR KIT (RH - passenger side) - this is PRIMARY fan (150w motor)
GM PART # 88890735
PACK QTY: 1
List Price: $144.00
Price: $74.16
DESCRIPTION: MOTOR KIT (LH - driver side) - this is SECONDARY fan (100w motor)
ACDelco Tech Connect info
15-8429 MOTOR KIT,ENG CLG FAN Left Hand
With RPO ENG OIL CLG(KC4) ^ EXTRA CAPACITY CLG(V03) ^ HVY DUTY CLG(V08) IDENT ASM# 22137220
With RPO EXTRA CAPACITY CLG(V03) ^ SEO AUX ENG OIL CLR(7P8) ^ SEO TAXI CAB(9C6) IDENT ASM# 22137220
15-8490 MOTOR KIT,ENG CLG FAN Left Hand
With RPO EXTRA CAPACITY CLG(V03) ^ SEO AUX ENG OIL CLR(7P8) Without RPO SEO TAXI CAB(9C6)
Without RPO EXTRA CAPACITY CLG(V03) ^ HVY DUTY CLG(V08)
15-8498 MOTOR KIT,ENG CLG FAN Right Hand
Without RPO HVY DUTY CLG(V08)
Rock Auto
Motor info (alt PN's - 22134671, 22136414, 22136897, 22137318, 22137319)
More motor info (alt PN's - 22105177, 22134671, 22136414, 22136897, 22137318, 22137319, 88892898, GM3116101)
I think some may have to redefine Extra Capacity Cooling System. I think it refers to higher air flow and not extra coolant as it did in older cars.
Z09B4U
Z09B4U is offline
post #6 of 28 (permalink) Old 05-16-2019, 11:42 AM
Boy I'm glad you found that post. It turns out the one I referred to. It de-mistakes my misspokes above. And yes it's watts. Both my cars have SPID V03. They both have the 240/150 setup, as the fan motors are nowhere near close enough in size to be interchangeable as Scott? reports the 150/100 are.
post #7 of 28 (permalink) Old 05-16-2019, 11:45 AM
In 94 & 95, V03 cooling fans were 150W primary and 240W 2ndary.
In 96 the 2ndary fan was demoted from 240W to 100W. (In 96, quite possibly to avoid relocating the fan relays outside the relay box, the only cars to get a 240W 2ndary fan, had a 7,457W primary fan.)
They are NOT Lying to You
You are NOT Lying to Yourself
Marky Dissod is offline
post #8 of 28 (permalink) Old 05-16-2019, 11:53 AM
Marky-, looks like overpost. But, would seem to contradict both my cars' builds???? Maybe your reply relates to only base Caprice/RM. IDK if both FW and FWB got V03, but my FWB does.
post #9 of 28 (permalink) Old 05-16-2019, 12:39 PM
Just paraphrasing what Scot Mueller said years ago; in 96, GM only paired 240W 2ndary fans with 7,457W primary fans (aka V92 & V4P, both of which require V08).
All other non tow pack B- & D- cars [in 96] got 150W primaries & 100W 2ndaries.
Check Z09B4U's quote: "In '95-'96 the V03 package was revised …"
(No insult to you or your cars' builds intended.)
post #10 of 28 (permalink) Old 05-16-2019, 12:59 PM
Z09B4U's Avatar
96Black My personal confusion on the 95/96 fan size is that the few I have seen had the cylinder(small motor) fan mounts left and right as per Scott(?). That is why I am looking for 95/96 one owner cars that are sure they have the 240W(flat motor) fans.
I do not want to perpetuate a rumor but I was sure people had swapped 150W motors for the 100W motors. Electrical connections would have to be changed but the cylinder style (small motor) case should fit both left and right small motor mounts?
Z09B4U
Z09B4U is offline
Similar Threads
HELP cooling fans with HD or without HD Rumble 96SS Heating/Cooling/HVAC 3 06-25-2010 09:53 AM
Anyone Switched From 1994-96 Hd Cooling To Dual Fans? skill3 Engine Problems/Maintenance 2 12-11-2008 09:30 PM
Different lights in different caprices???? snakey5138999 Interior 9 09-09-2008 02:57 AM
Can the three different interiors for the 3 different year impala's be posted in here bybcuz Interior 11 04-11-2007 02:10 PM
Different head gaskets for different compression ratios AdioSS Engine Performance 2 04-09-2003 12:59 AM
