Compressor Leaking - Chevy Impala SS Forum
 1Likes
  • 1 Post By jayoldschool
post #1 of 9 (permalink) Old 09-26-2019, 01:19 PM Thread Starter
Compressor Leaking
My A/C compressor is leaking Freon / oil where the case meets, front half to back half. or where the front shaft seal is.
Is there a good replacement compressor out there?
larryfs is offline
post #2 of 9 (permalink) Old 09-26-2019, 03:55 PM
The 4 Seasons premium compressor says it has dowel pins locating the two parts. They claim GM did not used dowels between the parts. i just installed a 4 Seasons compressor on my 95 Caprice wagon. Cold air now. I got it from RockAuto.
Ken
Ken Hennessy is offline
post #3 of 9 (permalink) Old 09-26-2019, 06:19 PM
jayoldschool's Avatar
Test the resistance on the compressor coil on the new compressor BEFORE you install. Speaking from (bad) experience, lol
jayoldschool is offline
post #4 of 9 (permalink) Old 09-27-2019, 02:29 AM
Mendonmafia's Avatar
I was told I had a similar issue with a compressor i got on amazon. I forget the brand. But, the shop I took it to warranted a the recharge for up to a year. After about 10 months I noticed my air was not as cold. The shop said the compressor was leaking in the same place you describe. I replaced the 10 month old compressor with a delphi unit which is so far working fine but when I took the 10 month old compressor one out there was no sign of dye or a leak other than a bit of dye where the hoses connect to the compressor. I asked the mechanic about this when going to get the delphi unit recharged and he said they sprayed it clean with brake cleaner...I think the 10 month old compressor was probably fine and just needed to be tightened where the refrigerant lines meet the compressor or at worst new seals. turned out to be a good time to swap though as there were a bunch of metal shaving stuck in the old 10 month old orfice tube which I was happy to get out of the system but I think the compressor was fine and that the shavings were from the previous compressor that locked up on me and took out my starter.
anyways my point is to verify the leak is from the compressor and not somewhere else. compressors are a b1tch to replace on these cars. Wish I did the bracket mod to make it easier to get the compressor off the first time I did the swap, but if I need to do it a third time its ready now. I'm sure this delphi unit will out last me now lol.
Mendonmafia is offline
post #5 of 9 (permalink) Old 09-27-2019, 09:54 PM
Sophomore Member
For what it's worth, they sell compressor rebuild kits on Ebay for like $25 that have all new seals. These compressors are pretty easy to disassemble and rebuild (assuming they haven't self destructed). I've had iffy luck with GPD and 4 seasons compressors on other vehicles; I went back to factory Denso compressors on my Chrysler vans and haven't had a problem since.
sherlock9c1 is offline
post #6 of 9 (permalink) Old 10-01-2019, 11:39 AM
What is this mod and, more importantly, where do I find out more details about it?
FleetwoodEstateWagon is offline
post #7 of 9 (permalink) Old 10-01-2019, 06:01 PM
The mod is actually in the FSM. Rear bracket, the one that bolts on the compressor, and then is on the block with a stud. On 94/5, that has a hole for a stud. So, you put in the vise, and slice the hole open so you can slip it over the stud.
sherlock9c1 likes this.
post #8 of 9 (permalink) Old 10-02-2019, 06:12 PM Thread Starter
Does this mod apply to the 1996 ?
larryfs is offline
post #9 of 9 (permalink) Old 10-02-2019, 11:02 PM
See quote below. Basically there is a hole in the compressor bracket that attaches to the block. You turn that hole into a slot. This allows you to remove the compressor easily and more importantly without removing the entire bolt, which can be a royal pita to get back in.
^^^ this is the mod
I don't believe so. I think GM took care of this in 96
Richland, WA. Moving to Cocoa Beach, FL by November 2019
1994 9C1, 18x,xxx miles
shorty headers, cat delete, CAI, TB air foil, MSD cap and rotor, air pump delete, bosh double platinum plugs
2" front belltech drop spindles, 3" rear drop coils, rear airlift 1000
Cadillac Deville heated leather seats
looking for blue door panels with power window switches, upper and lower dash without holes, power window components and harness, and cruise control components and harness.
