Austin Wrench-A-Part Fresh Cooling System Parts - Chevy Impala SS Forum
post #1 of 1 (permalink) Old 07-14-2018, 03:35 PM Thread Starter
juniorwatson's Avatar
Guys,
I was down at the Austin/Del Valley Wrench-A-Part JY today, and even though the pickins' were an F-Ton 'lot smaller than I expected (I typically go to Belton), there were some new looking components I thought I'd let everyone know about.
One was a new looking water pump, and the second was a new looking radiator. Both are currently on rows 83/82/81.
Heres the pix from the donors:
juniorwatson is offline
