Door Projector Lights - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 08-30-2013, 09:02 AM Thread Starter
A Local Car Club Member saw these.....
http://www.ebay.com/itm/Car-Logo-LED...ht_4820wt_1141
Anyone else seen these and what are your thoughts on these kits?
You can also send them a JPG and have your own image installed. From other pictures I've seen online, it look like the image on the ground is approx 2'-3' in size.
post #2 of 4 (permalink) Old 08-30-2013, 04:36 PM
connman's Avatar
im not usually into stuff like that but i like this and might even give it a try. If i do ill report back with how it is
connman is offline
post #3 of 4 (permalink) Old 08-31-2013, 03:57 AM
Reds ss's Avatar
Oracle sells those
I believe thats the company that makes them for Oracle...not sure,,,,i had some custom made...it does look bitchin at night....definately gets the looks...esp when you lower the car and image gets larger,,,Oracle is Much more expensive...of course...but you get a warranty and get it within a week
396 Lt1. TT 67mm Turbonetics. AFR RACE 227. TD Shaft Mounts, 3.5" Oval/Xpipe Spintech. CPT Level 3 4L60E. 3200 Vigilante. 3.5" Polished Ford MMC Driveline. 3.73 Eaton Posi. SPC Total Adj. Castor/Camber Upper/lower arms. Spohn Racing Del-Sphere upper/Spherical Rod Ends Lower Trailing arms. Accuair ILevel . Ipad 4 with Wifi. 12V Istreamer. 8000 watt. Gladen Amps. 22-Dynaudio Tweets/Mids/Midbass. 4 -Shok Industries Elite X 12 Subs. 6th Order Bandpass. 152db.
Reds ss is offline
post #4 of 4 (permalink) Old 09-01-2013, 12:43 AM
Boilermaker's Avatar
We've got a good stock of these with the Impala logo in the three car colors.
Gene Zebley, aka "The Boilermaker", "Godfather" INC for Life GOD BLESS GEORGIA!
1996 ImpalaSS, Black Sunshine (Driving while knocking out the last items on the punch list)
Boilermaker is offline
